P700 code 29 low idle and hard start
marc_nelson1
stuart
Hey guys have a buddy with a 2014 p700 and getting a code 29. Have to start in neutral and give a little throttle to get it to start up. other than that it runs great. Put a new cam in two years ago and hasn't had much run time on it since s deff don't believe its contributing. I know the p1000 had harness issue with there idle air control. any help would be appreciated.
115,286
Welcome from Michigan!
Where is the state called Stuart?🤔
I know this is about your buddies P7. Do u have a Honda rig or are u just strictly helping your buddy?
If you have a rig we suggest a welcome thread to start with and pics of your rig or….
Pics Or It Didnt Happen!
As for your issue. We always say to check the forums search up top first, chances are its in there.
There were a bunch on code 29
Heres one of them that might help
HondaTech
Sounds like the IACV is stuck on a low idle position.
The Rincons used to do the opposite and stick in a high idle position.
Try removing it and turning the key on with it plugged in. If you hold the barrel it's should move on the pintle a bit before it stops. If it doesn't move or feels locked to the pintle it needs replaced.
