P1000m3 Underseat Cooling fan
RedFred1
RedFred1
301
619
North Carolina
I am in the process of completing the fan install for the cooling fan I installed under the seat. It is a 7" fan with a plastic housing. 80 watts @ 12vdc. I used aluminum angle and made 2 L brackets. One end attaches to the seat frame, the other to the floor brace. I intend to add a Broan 8" metal filter to the open side.
I have the wiring pulled and will be tying it to a reversing switch on my dash. In the summer fan blows past motor under bed, winter it blows into cab. I am also toying with a thermostat to start it automatically at some preset temperature. The little controllers are only a few bucks and come with an RTD.
FredD
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
View attachment 83564 View attachment 83566 I am in the process of completing the fan install for the cooling fan I installed under the seat. It is a 7" fan with a plastic housing. 80 watts @ 12vdc. I used aluminum angle and made 2 L brackets. One end attaches to the seat frame, the other to the floor brace. I intend to add a Broan 8" metal filter to the open side.
FredD
Looking good
RedFred1
RedFred1
301
619
North Carolina
So I am continuing on my buggy mods... I am changing the intake tubing and had a chance to get back under the seat and install the fan filter...
I got an 8" microwave vent filter...
Since the fan was 7", I cut a little pie shaped wedge out of it and recrimped the edge. I also shaped the filter so it bulged out away from the blades so it would not interfere with the operation.
Now when the fan reverses, it won't suck in any debris or get sticks stuck in the blades...
FredD
Reactions: elkguide and BWAF
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
that's going to be one of my winter projects.
A couple observations though..
why the big 8" instead of a pair of 4" bilge fans?
do you think its far enough from the plastic panel to pull air properly?
While I like the idea of protecting the fan blades, I'd be concerned that the filter would inhibit flow... have you tried it yet?
Reactions: BWAF and BigOL3
RedFred1
RedFred1
301
619
North Carolina
All great questions!
I wanted a straight flow without ductwork, hence the single fan...
There is at least an inch between the fan and the plastic seat base... actually closer to 2". If you notice in the picture it shows up behind the wiring bundle... I am going to try it without drilling holes in the seat base for the heat mode. The microwave vent fan filter is pretty porous. I have it wired and will test it shortly after I reinstall the seat base... blows pretty good with no seat! Also the filter is not right up against the fan shroud, there is a gap may be 1/4 to 3/8"... it's experimental, we'll see!
Thanks,
FredD
mjn
mjn
1,409
5,206
Thanks,
FredD
Cool!
Keep us posted!
Reactions: BWAF
mjn
mjn
1,409
5,206
Another question;
How much of a bioch was it to take off all those interior panels??
Reactions: BWAF
A
Andy-R
9
11
Arkansas
We took our first 1000-5 ride in the woods today,90 degree heat. The rig handled the mud holes well. Our only complaint was the engine heat to the seat was pretty bad.
I like the fan idea for later but need an insulated shield or something like that, looking for ideas before I go on Amazon.
Dove season next weekend!
Reactions: BWAF and Farmer
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,601
Oshkosh, Wi
Is that fan waterproof? Does it have any kind of circuit protection in case debris gets in the fan or will it just burn up the motor?
Reactions: BWAF
Zax185
Zax185
59
148
Montgomery, AL
6C008CEC 405F 45AB 8FA3 EC99AAD10FC7 B7740126 3545 4626 93C7 4208C6356764
I went with the pair of bilge fans but I would go with what moves the most air and uses the least voltage. The 7” looks great and interested to hear about voltage drop, noises, and air flow.
Reactions: BWAF
gpshemi
gpshemi
31
Lapeer Michigan
So I did this mod about a year ago or so. I firat had the 4" bilge fan. it worked ok, but is really noisey. Then I switched to an automotive 7". It flows about 4 times more air, amd when it was new, you could hardly hear it run. It's still quiet.. It works well for the front, but I've also found it turns the rear footwells into a blast furnance. My next move it to pipe some of it out the skid plate like DEI's kit.
Reactions: Zax185 and BWAF
A
Andy-R
9
11
Arkansas
looks like there's a "casbin comfort improvemenyt kit" for 16 & 17's. I'll check with a local dealer for getting it done on Honda.
thx
Reactions: BWAF
mjn
mjn
1,409
5,206
Well, given the fact that I don't have any rear footwells, that sounds good! :)
Did you mount it the same as the OP? Do you use it in reverse in the winter?
Reactions: BWAF
mjn
mjn
1,409
5,206
FredD
Another question; Considering there are only two wires coming from that fan, ie; pwr and ground... how are you going to wire it to reverse at will?
The answer is probably simple, but keep in mind, when it comes to electrical stuff... I'm retarded. :)
Reactions: BWAF
Tramguage1
Tramguage1
Texan
7,140
27,147
Somereset, Texas
By reversing the wires will cause the motor to reverse directions.
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
Dpdt switch
mjn
mjn
1,409
5,206
Okay.. seriously, I already have a 3 position switch on my panel for "fan". it's already grounded, and there are obviously two pwr wires coming off it..how do I wire it so it'll run either way?
Reactions: BWAF
BWAF
BWAF
8,857
42,437
Carthage MO
It has to be double pole dual throw to switch polarity like this 80897bb4dd307c305f2071972bcd758c
Reactions: mjn
Tramguage1
Tramguage1
Texan
7,140
27,147
Somereset, Texas
Double Pole / Double Throw
Reactions: BWAF
