P1000 Copnhgn’s 2018 1000-3 LE Build
Copnhgn
17
Andersonville TN
Not a big one, but an important one. Had some time to get my first accessory added last night.
I will be using the pioneer to work with my bee hives, the propolis from the boxes stick to everything and is very difficult if not impossible to remove. So I want to put some kind of mat in the bed.
I ordered a 4’ x 5’ x 1/8” Rubber cal diamond plate sheet rubber. Then just cut it with a utility knife and exacto knife to fit. Needs some time for the rubber to lay down since it was rolled up but fit turned out well.
I did not cut holes for the bed tie down stakes but may go back and do that this evening.
CEF2D5A5 2F3E 4721 8D64 7BBEEB4CD8F0
6124DCBB F1AD 421F 82F5 D8D7B396FADA
E80A4E73 16FF 4F37 B715 4BB1D9290B44
TripleB
TripleB
11,678
99,161
Caryville, Tennessee
View attachment 203198View attachment 203197View attachment 203196
Is that your honey that they sell at the CO-OP in Clinton?
Copnhgn
17
Andersonville TN
Looking for some advise/suggestions from some folks that have installed a fuse block.
This area looked like a lot of dead space and would be out of the way, but now I’m wondering if it will be to inconvenient if I need to check something. The plate and the whole assembly can be pulled out with two screws as long as I leave the wiring long enough.
Still going to add a solenoid but haven’t received it yet, just couldn’t wait till I got it before I started. So the wire currently on the fuse box will be landed on the solenoid then a new wire will run from solenoid to fuse box.
9FC23120 82AB 45DD AD11 A49845D2C5D0
5E703F3A F1B1 4C5C B426 E5F8B5C56E6D
EFC93085 B7E0 4530 9836 4F568345207B
39EF9309 0432 40EC 97DC A03D23455DA5
BD35BA2C BA7D 4C55 903F 0EC9DC2505A7
CC2749D7 0F7E 48EC B360 31D32650B23A
Reactions: TripleB
