P1000 Couple questions
500
500
589
932
Are there any hose fittings connecting the hard pipe between the one just below the intake and the one just below the two balloon looking things off the pipe?
I've checked hose clamps for tightness, but did not know if there were any in between? I looked through the skid and did not see any, but want to be 100% I'm not overlooking one. The one below my intake was pretty loose. The two below the balloons were tight.
Also, how much spline is showing medially on your shifting fork shaft? Mine has been tightened down laterally to where it is almost a couple millimeters inside the lever. All splines showing to the engine side, and none on the other side. Didn't know if I needed to even it up (slide it rearward toward the engine), or if this was normal and how most were set from factory.
Thanks
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
No idea on the splines but sounds like you've covered all the hose clamps. There's a coupling at the air box and one right next to the balloon things you mentioned and that's it for underneath.
