Sportreac
On Jun 10, 2017, at 5:49 PM, Larry and Gail <
[email protected]> wrote:
No on the bolts. I bought a metric studs and 7 Nuts. You double nut the nuts into the dash and double nut the upper. Then tighten the dash portion. I used a washer that fit the opening there. Undo the uppers remove them put on the plate. Add a small metric washer , nut and tighten. You can make the revel of the stud flush with the top of the nut by adjusting how much you screw the lower portion into the dash. The plates also come flat. You need to bend them to fit the dash. I used a ratchet strap around a propane bottle and the rubber end of a hammer or assist. Hope this helps
On Jun 10, 2017, at 2:41 PM, The Honda Side by Side Club! <
Montana,
sporttrac4x4 started a new conversation with you at
The Honda Side by Side Club!.
Cover for shifter holes
Are you using the same 2 bolts to hold the cover on and if not does it come with them if you buy one?
View This Conversation View All Your Conversations
Please do not reply to this email. You must visit
The Honda Side by Side Club! to reply.
This message was sent to you from
The Honda Side by Side Club! because your preferences are set to receive email when a new conversation message is received.
To stop receiving email, please
edit your contact preferences.
