This is my first post in this group looking for some guidance.
I hit a rock on driver side. In result, absolutely crushed my bottom A-Arm and cracked my front diff housing/casing only on the driver side. Is it possible to buy a new housing/casing since it’s the only thing that is damaged, as far as the differential, or do I have to buy a completely new Front Differential? I would like to spend less money as possible. Any input would be great if anyone has ever dealt with such. By the way, inside the the differential is fine, only the housing/casing is cracked on one side only. Thank you!
