I have read through alot of threads but cannot find anything so I'm making this post in search of a little help before I pull all my hair out..
Issue started while driving through tall wet grass checking fence, the machine stuttered a little bit but then came out if it, proceeded on with the rest of my day just fine. Parked it in the barn and the next day it wouldn't start at all.
I'm now getting code 64. I have replaced the battery, the relays and all fuses are good. The injectors ohm out good per the sevice manual, and I have replaced the injector clips. I have verified the relay circuits are good and I cannot see any visible wire harness damage. But there is still no power to the fuel pump.
Has anyone had code 64? Or anything similar to this issue?
2017 1000-3
2017 1000-3
