P1000 Cv boot oddity
70,279
We just have hammers and blunt screw drivers
I'm dropping it off at your house to do it correctly LOL! But in all seriousness I will pop in that new axle and learn how to rebuild a CV joint or just add more grease whatever it takes and throw it in the back of the truck!
Rambo
Rambo
339
822
Southern Indiana
Take a temp reading of the new axel cv’s with your setup!
Funny this came up..... Just put All Ball rear axles in and ran them this weekend along with my buddies. After we got back I checked his cv temp to the touch compared to mine, and wow what a difference. Mine would sizzle when hit with water. I remember you had a similar situation with some rhinos. Whatever became of that?
I’m still running the second set they sent me. They still get hot.. so I said, “f*** it and ride!” I may be pulling my lift so it will be interesting to see if they quit after the angle change.
70,279
My stock ones, were warm @theelectrician put his paws on it and said omg they are hot. So I took his word for it lol
Reactions: BWAF
The stock axles didn't get hot on mine.. nothing like the aftermarket. But that’s not to say a new stock axle wouldn’t get hot.
Reactions: BWAF and Plumber32
Rambo
Rambo
339
822
Southern Indiana
I'm in the same boat with my lift. Really don't want to pull it off! I'm going to see if I can drop it a little with the preload adjustment on my shocks, see if that helps. If not may just go back with stock axles. There getting hot enough now I don't trust them.
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Can't see a tear. Just the goofy clamp and grease inline with it. Gotta admit I figured the tune that @joeymt33 plugged into my motor blew it because of the smoke that came out at a high rate of speed. Thank God it was only a CV joint
I had the same thing happen to a driver side rear last Summer. Still not sure how the grease was getting out. I wonder how common of an occurrence this iso_O start a poll
70,279
I'm sure its a combination of aggressive driving or high speed and the lift. I'm going to drop the preload. I won't give up the lift, it's been to valuable for me. I'd rather fix a boot every 2500 miles than have a polaris go through something I got stuck in!
70,279
You running a lift?
Reactions: BWAF
Yeah SATV 3 inch and 30s. I compared the heat after a back country road trip about 10 miles and a speed of around 35 mph. My buddies unit has a 2 1/2" lift with stock axles and 28s. Like JTW mentioned never noticed the heat with stock axles????
Stock axles didn’t get hot.. I even took off an aftermarket and put a spare (used) stock in just to get a temp reading.
Reactions: BWAF
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
My passenger inner boot did identical thing. Never did find where it came from. Ordered both boots from local dealer (kit with both boots was only 10 bucks more than one boot lol). Came with grease and clamps. It wasn't expensive either. Around 60 bucks if I remember right.
Rambo
Rambo
339
822
Southern Indiana
I'm not very educated in all of this but got some feedback from a couple friends. They mentioned the stock axles having smaller bearings allowing more movement or angle vs the aftermarket axles with the larger bearings. It seems to hold some truth seeing this problem with both Rhino and All Ball axles.
Maybe the CV had too much grease initially? One of the CVs that I had rebuilt myself was leaking grease. I believe it was because I had packed too much inside and when the CV was compressed it would push the grease out. It was an inboard CV which makes sense because they are the ones that can slide in or out.
Well, some of the things the aftermarket’s advertise is running cooler, increased articulation and strength! But with all that said... they were great to work with! I’d buy them again despite them running a bit hot. I’m curious how they’ll read now that I’ve put some more miles on them. And again... the only time I noticed the heat was running full speed blacktop.
