P1000m5 cv boot replacement
crazychris
crazychris
249
532
redfeild arkansas
ok guys I got a leaky front cv boot. the one close to the differential. that's called the inner cv boot correct? I have never had to replace a cv boot so....what does it require to remove and do I have to replace both cv boots?any special tools required? I putting up some pictures I dont see a hole but grease does seep out. also found this cv boot replacement on Amazon anyone have experience with these. thanks In advance. Cee8dcea0aae2df9cc6a82c27c6c3ed1A2b6227f94bde143b481a442d48568e234f2b7d502c48da9211986d010435657Ca454bb05a6f90d1ddebf7eb641df96c
Reactions: BWAF
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
@joeymt33 video above where he shows you how to do the bands. If you buy the factory boots they come as a kit with both pair in the kits along with grease and new bands. If you take to a honda place to fix don't expect them to have the boots instock.
Reactions: BWAF
It’s a whole lot easier just to cut the band and install a new one. but if you have to remove one of the old bands and save it you can give it a shot.
You do need to pull the boot off and remove the axle shaft from the CV to change the boot.
Reactions: BWAF
nbomar
nbomar
4,416
17,854
Springdale, AR
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
Nowhere near as bad as mine... I have ALOT of grease everywhere on passenger rear.
Yeah...im pretty sure its not even torn ....just slid out of the clamp a little...Ill take the clamp loose and check it though.
Reactions: Plumber32 and BWAF
67,347
Well mine decided to sling some grease this evening. Best i can tell there is no tear in the boot but it has slid out of the clamp just enough when hot to push out the grease.
View attachment 80097 View attachment 80098
That's what mine did. I was flying and boom smoke! Thought I blew the motor for a sec. Cv grease on exhaust. Once off I found a tiny pinhole.
crazychris
crazychris
249
532
redfeild arkansas
I though it had slipped off the clamp enough to let grease come out but....kinda far from the clamp. I am thinking I have a pin hole. so....
is this the inner boot? I know it's a dumb question but got to ask? also clamps do they use a special tool. I have a otinker clamp tool. and do I have to replace both boots or can I just replace that one. never have had to replace a cv boot but I can imagine a stick found a way to puncture it before I got a arm guards. rode threw a clear cut several times.
Reactions: BWAF
267,233
I think this tool will remove and apply the Honda type click clamps, but I am not 100%
https://www.amazon.com/Pliers-Clic-R-Swivel-Mercedes-Collar/dp/B074BSSVCX/?tag=sxsweb24-20
I have just butchered the old clamp and poorly attempted to crimp / click on a new one with pliers and vise grips. I should have just spent the $14.
crazychris
crazychris
249
532
redfeild arkansas
done that before on my can am Outlander. they use otinker clamps everywhere. tried clamping one with out proper tool. bad ideal. lol. I think I will end up going with the all balls cv boot from rocky mt atv. and get that $9 tool along with it. I know it's a small hole but I surely dont want to thrash a cv joint. lol I drive it like I stole it so.....
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
I ordered the all balls boot kit, band tool and cutter this morning.
