P700 CV repair and boot replacement.
I thought I'd take a few pics while replacing the boot. This is the rear outer CV.
I chose to remove the spindle and knuckle. It was easier than and less messy than pulling the axle through the knuckle.
67bf144017860d42e41c02e0bc0e6652
Here's a pic with out the knuckle.
26c7fc46abd1125d303a1ee5e642c58c
Boot had been removed.
9718c9f962828f07c2a7d3cc8cd9c5e4
Give the axle a tug and it should come out. I placed the axle in a vice and used a hammer and chisel to punch the CV joint off the shaft.
4265beb3e96f0152d2ac4116ffb9dfaf
After marking the inner and outer races, you can turn the cage so that you can remove the balls. I started with the one I marked and removed them in a clockwise rotation. This way they go back in the same place.
B1e36c48e85deb339a85c00f73e97362
All my balls!
79006e8553986a5786d60cc401fb2328
Here is the unit with the balls removed.
398a08c3b2a268326a84f59e302832d4
You can now turn the cage vertical so it can be removed.
22714bf6632ab909caa40311543d06ce
Once it's removed, you can remove the inner race.
B0982921ec87c22be8730a04cbc22657
I did not have to replace anything. I only disassembled it to make sure it's clean after the ride back with a torn boot. Here it is after clean up.
2149b62977da0e8095bccdef7e0e21ba
Reassembly is pretty straight forward. Just be sure to use grease everywhere prior to reassembly.
617bfa45ccb2c54b7c0fb8451cf4fe24
Here it is all back together.
Eb014ca0348f2af3b95a6d27c815d1fd
The next step is to wait for the UPS man to bring the new boot.
More to come.....
Joe
I just got in from a work trip and found the boots have come in. I'll get a chance to install it this weekend.
Reactions: sharp
I slipped the clamp and boot on before putting on the CV joint
4cb0d679bf734952e4e12434ca36a6d2
The clamp is pulled tight and locked down
4b5d713f8d5abc9959efff6b3291a6ad
I put grease in the joint and then filled the boot with the remaining.
2cf744b3e295408143503bbe7e541af8
I slipped the CV back on the shaft, you may have to use a punch or screw driver to keep the retaining ring pushed in the groove while tapping on the CV.
Acbba25e798bdbb175c2af970947a6c7
Make sure to grease the seal in the diff. I used grease liberally on the splines and sealing surfaces.
2366fb70b23b8e8c51f95354a065f3c0
I grease the knuckle the same way and reinstalled it. Make sure you use a new cotter pin.
3d38b54bf3637ef9efc1fb1bad81531a
Now time to have fun again riding!
Joe
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
Thanks joe. I know a lot of people will find this very useful!
HappyHonda
HappyHonda
50
34
you're the man! @joeymt33 thanks for the awesome write up with pics!
Reactions: joeymt33
271,888
Nice write up and quality pics. Thanks!
Those dog gone rubber boots are the achillies heel of everything off road.
Reactions: QuadMan747
I really need some better guards but all the guards I've seen are meant for stock wheels. I've got offset wheels and wheel spacers so I need an extended guard to cover the gap. I will probably make some one day. I just can't find time to do stuff like that. I still haven't finished the fender flares. One day soon.....
Thanks for the kind comments. I learn a lot from forums so I try to give back.
I still need better CV guards. This happened today. If I could just get the time to, I could make some. Good thing I drive a Honda, I've got time to ride but no time to repair.
6d227561e9021c76ae45790530ff7122
47c80cac8929b80e5c13043cae84c98c
Joe
Maybe add a flange of aluminum? You could screw it on adjust it to fit your wheels?
Reactions: joeymt33
That would look like a redneck thing I would do. I'll put that on the to-do list.
Figure out the width and then make a cap you could rivet on could make it higher and wider.
Jdurbin
All my balls!
Is there a trick to getting the balls out? i can't
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
@joeymt33 knows a trick or two, I know he would be happy to help!
solrus
solrus
1,629
2,511
Montana
Joe
"Make sure to grease the seal in the diff. I used grease liberally on the splines and sealing surfaces. "
Did you use same grease that came with CV boot repair kit?
