P1000 Dale's P1000-5 build
dale5740
dale5740
886
417
mt airy md
keep me updated can u post any pics sounds real cool
T
TheBob
58
57
North West Arkansas
I haven't actually wired mine up to the reverse trigger yet, not sure if it only works with the headlights on also. I'm assuming that the pig tail was for the back up alarm, so I don't think the lights need to be on.
I'm like you, haven't done this yet as still waiting on the parts to get here, but I think on the above diagram, if you bring a positive 12v lead in from the tail light wire into terminal 86 (don't split it off the 12v positive lead going to 30) AND use the sub harness negative trigger to terminal 85, the relay will not switch unless the lights are on AND the unit is in reverse. Tail lights will provide the power and the reverse will provide the ground, completes the circuit for the coil in the relay to energize....at least that's my theory....
A
AK_Centurion
271
330
Eagle River, AK
That will work. I may end up doing it that way too. Just leave the headlights off and you have stealth mode. I wanted the lights to come on so who ever was behind me knew we would have to back up. I guess I always ride with my lights on anyways, so that will work for me.
dale5740
dale5740
886
417
mt airy md
so u are saying when headlights aren't on nothing will work reverse lights or rear running lights?
CashMoney
CashMoney
329
211
Reno, NV
www.SRTNV.com
Yes, he's using the 12v hot wire powering the lights going to the + side of the coil in the relay. So they will need to be on in order for the backup lights to work.
dale5740
dale5740
886
417
mt airy md
idk can't see why that would be bad but IDK. I might do a flat rear bumper and put flush mount led's in it like rock lights the real bright small ones or flush mount led 6 bulb ones then run them off back up alarm. then just have to rear facing pods for lights to turn on whenever I want. I just have to do the bumper
dale5740
dale5740
886
417
mt airy md
IMG 1325
IMG 1326
IMG 1327
IMG 1328
IMG 1332
IMG 1330
Images
Reactions: pct and CashMoney
A
AK_Centurion
271
330
Eagle River, AK
Powering the relay from the taillights would keep the lights from coming on in reverse, unless you had the headlights on. You would still be able to turn them on with the dash switch when ever you like.
T
TheBob
58
57
North West Arkansas
I think in that case you would want to wire up two separate control circuits. The back up lights could be run as described using the relay powered by the tail light and ground trigger, the rear pods to turn on whenever you like could be controlled by a switch. I am using the same set of lights as backup lights and as work lights. I mounted them tonight, did not wire them up. Going riding tomorrow to see how well the brackets work.
T
TheBob
58
57
North West Arkansas
Oh, and good job on the mud, reminds me of my younger days! Did you have the winch mounted already, or is that on the wish list now?
Reactions: pct
dale5740
dale5740
886
417
mt airy md
no sitting in a box ready to be mounted lmao!!! I told myself it will be ok Ill just stay away from the mud!!
Reactions: pct and Delton
dale5740
dale5740
886
417
mt airy md
can't I just get the harness for back up alarm and that will basically do it for me? then the switched lights up high
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
That plan worked well for ya huh? Lol
T
TheBob
58
57
North West Arkansas
That might work, but without testing it first I really don't know. Seems like it would, assuming the sub harness has a hot wire, and then plug the back up light ground wires into the negative trigger. Test it and let us know!
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Oh and btw...that ain't mud. You can still see your tires lmao (jk).
IMG 20160315 135344654 800x450
Reactions: joeymt33
dale5740
dale5740
886
417
mt airy md
View attachment 12431 View attachment 12432 View attachment 12433 View attachment 12434 View attachment 12435 View attachment 12436 View attachment 12437 View attachment 12438 View attachment 12439 View attachment 12440 View attachment 12441 View attachment 12442
u were planning on getting stuck
the pics I posted were when I first got stuck when i was still clean enough to take pics.. 2 hours later I was really stuck!!! then an hour after that i got out and said screw the pics lmao
Reactions: pct
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
That is some nasty looking mud lol.
Reactions: pct
Similar threads
