P500 Damage due to NO skid plate?
Where can I purchase? Like others here, I can use the original skid as a template.
Source the UHMW Locally.
A 1/2” 4x10 sheet will run you $500plus.
PSA: Don’t try to heat past 230-240F to bend it, it destroys the molecular bonds in the plastic and it starts to crumble. Without proper equipment you can’t bend it past @15-20 degrees.
BUT you can buy a Trail Armor skid for what you can make one for, and it will be pre-made and have all the hardware to install too.
solrus
solrus
1,629
2,511
Montana
1/2"for p500 or p700 is overkill. 3/8" is perfect thickness
Sent from my Moto Z (2) using Tapatalk
103,828
Like underwear, it’s best to have and not need them than it is to need and not have them. Those skids.... my UHMW Fromm SSS OFF-ROAD totally kick ass and have saved my ass on many occasions.
Alan aka Davinci
Alan aka Davinci
Mr. Meme Master
16,771
183,173
Grand Junction, CO
I also have the SSS Off-Road skids, they are pricey, you can't damage them and they fit the Pioneer perfectly.
solrus
solrus
1,629
2,511
Montana
If you find 4x10 3/8 sheet for around 300$ then , DIY is better and cost effective , since u can make 2 plates.
But if not, then SSS is next choice but look for overstock.com coupons and dont tell the SSS to price match they are greedy and will complain to the seller not to honor any coupons or discounts.
11,371
84,772
A rock might damage the machine, a stick thru the floorboard might puncture your body. Skids for either rocky or wooded terrain is money well spent.
UHMW or Aluminum, DIY or aftermarket bolt on? Kinda like Chevy or Ford question, to each his own. Went with full Ricochet aluminum here, most single expensive mod to date. Because of the thin plastic wheel well, sent template to Ricochet and they made two pieces of same aluminum material for inside the front wheel wells. Think it was around $25? Painted black and bolted to wheel well, may not be the best looking, but gives piece of mind. Thinking @trigger did a better wrap around approach.
8D9EC21D B29E 478F BFCF C20653FB11C1 4E76E6F8 E604 4395 B4CD F637BFAE4D42
Reactions: crazychris
