0860silverado
Hello everyone. I, like many of you with a windshield/roof/rear panel setup, have been struggling with dash heat through the shifter slots and seat heat. I've seen several innovative solutions on this forum to solve these issues that are very effective, and I'd like to offer my solutions. For the seat heat I ran a continous sheet of automotive double sided foil heat shield from the front of the seat frame to the top of the frame for the seat back with the only openings being tiny slits for the seat belts and locating pegs/hooks for the seat bottom. Works wonders! Great! Problem solved. Then I was going to mod my dash using one of several ideas I saw on this site and then I had an idea... The crux of the problem is caused by a low pressure condition created in the cab at speed causing radiator heat to be, not blown in, but sucked in through the shifter slots and steering column. So I figured... All I gotta do is overcome the pressure of the radiator- heated air and get some ambient temperature air coming through those slots. So I came up with this...
