Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I believe 1 5/8 and 1 1/2 od. Front and back different. The 1 1/2 rear was a little loose you could grind down 1 5/8 to fit
10-4 thank you sir. Metal shop can't get 1 5/8 so guess I'll order online. Good thing I won't need much of it. What length did you cut your sleeves? Got a quote for the 1.75 and 1.25. Both are around 60 bucks a stick. Soon as I figure out how much I want I'll order it. Be here tomorrow.
I just put in 3 in pieces. The one over head in the area that has to be extended I used 6 in.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Ordered one stick of 1.75", 2 sticks of 1.25", 1stick of 1/4x2" flat, and 1stick of 1/4x4" flat. Metal will be here in the morning. Picked this up on way through town. Works really well.
IMG 20170124 171047299 1336x752
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Found a tiny bit of tube I could play with on the notcher. And since I ain't picked up that torch since my last weld pics, I thought what the hell. Not picture perfect, but I'd roll with it any ole day.
IMG 20170124 204028699 1336x752
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I'll look into another angle meter. After that first screw up I tried placing a level on the bend I already had. It seemed to help.
Reactions: sharp
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Ju
So what are you up to? Sliders.. Bumper..Cage
Just wasting material man. First time ever even touching a bender. Luckily I did remember the instructions I was given when I picked it up. Other than forgetting to close valve on cylinder a time or two lol.
May start with a bumper first. Probably the simplest thing to build. Maybe get some confidence up and then start on the harder stuff.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
I usually put the level on the center die and then on the already bent piece. The clamp helps keep it indexed if u pull the pipe out and go back in with it. I do eyeball the bend to the center die to line it up also.
Similar threads
Replies
Views
455
P1K5Dave
V
Replies
22
Views
2K
Replies
Views
3K
