P700 Differential lock
Mudzillah
Mudzillah
5
Florida
Hello,
I have a 2019 Honda 700-4 and after a trail ride I noticed when I activate the 4wheel diff lock, the light periodically flashes... Almost like the differential is locking and unlocking... Wondering if this is normal or do I need to take it to dealer for warranty repair. Any info is much appreciated
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
check your front diff to make sure there isnt anything hanging lever up. if nothing there ,then probably linkage is off a little bit
Reactions: Backwoods
Mudzillah
Mudzillah
5
Florida
I thought the diff lock was only for the rear differential?
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
no rear diff is always locked as its a full spool set up. the 1000s and big reds are the only ones with 1 wheel drive capability. on your front diff on the passengers side there is a lever coming out with springed cable attached to it. ill grab a pic in a minute when i get home
Mudzillah
Mudzillah
5
Florida
Gotcha, I noticed when I was spinning the right front wasn't pulling so guess it's not locking... Thank you and I must have to adjust something...
Mudzillah
Mudzillah
5
Florida
I adjusted it this afternoon and everything working fine.. thanks again!
