Well a few years ago I rigged up a way to load my P500 in the back of my flatbed by using a second set of ramps to get the front wheels up on the headache rack. The racks never supported load while traveling. I made a post about it on here somewhere. I used some of your guys suggestions and had it where the 500 locked in tight but I still could haul my camper. My final setup used wheel nets over the back tires, chain binder from the front bumper of the 500 to the heache rack of the truck, and a 2 inch ratchet across the footwell, and a final safety chain from the rear hitch of the 500 to the truck. Worked really well. A bit of a pain having to unhitch the camper trailer to unload the Honda but it is what it is.
With my new 700-4 Deluxe arriving soon I wanted to get a similar setup prepared for it. I'm going to bring it home on a trailer so I have some time. Anyways, I was going to build this roof cover to weld to the headache rack so I can bring the 700-4 more forward. This way the rear ROPS would clear the camper when turning and the weight would be more over the rear axle of the truck. Plus with this rack I can do wheel nets on all four tires.
I'm also going to mount a winch to the headache rack that I can run to the rear hitch of the 700-4 to load it up with. On the 500 I just drove it up but I'm going to have a bit steeper ramp angles from the flatbed to the headach rack in order to get it over the roof more and keep the height down. I think with the winch I will increase the safety and it won't be as sketchy. I think for unloading I can probably drive off.
Anyways, here is my design for the rack. It will be a main frame of 2x4 steel with 1x1 square for the wheel platforms and chock. I might even add an LED light bar to it at some point. And I realize I'm not much of an athstetic designer. Hahaha.
Sent from my SM-T870 using Tapatalk
