P1000m5 Dragon21's build
Dragon21 submitted a new Garage Item:
Here We Go Again... 1000-5 This Time
Well, now that the 700-4 is gone and the 1000-5 is home. its time to get started on the build again. I really try to go slow and pace myself. however that doesnt always work that way. When i got it, it had roof and windshield as part of the deal.
Ordered a winch and mount, synthetic rope and fairlead for it, HL snorkel, Amazon switch plate, fuse box, 100amp disconnect.
still plan to get a honda front bumper, lightbars, and soundbar.. when money permits.
debating about dual battery setup... not sure if ill do that or not. I dont tend to use radio or lights when its not running.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Ready to get these on this weekend and see how they ride. 35B6A93A E329 47EE A2D4 AE4EED2ECF9E
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Finally got the wheels back on the ground. Thinking I need to adjust the toe in a little. Looks like it’s pointing out. Shocks were set with about 7/8” thread showing. Gonna start with that and ride it to see if it needs adjusting.
6C7C9E83 BA73 46AB 9A56 68D74B4B9A51
586A3440 6DAA 4999 9DFF B83290DE0D66
47504CC1 F05F 4FA1 BE2A 066997ED1330
208,011
BigOL3
BigOL3
2,994
8,918
Reactions: BWAF
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Does that intake pipe end there by the dash?
yes. its a radiator hose. worked pretty good.
Will that type fan be reversible to be use to blow heat into cab in the winter?
it can be setup to push or pull air, but i no longer have it. Was running when i got a little deep one time and it died.
Reactions: BigOL3 and BWAF
BigOL3
BigOL3
2,994
8,918
Did the heat under the dash have any adverse effect on the intact. I have NO plans on extending the intact thru the hood, but kinda like the hose ending in dash and removing the OEM air box from under the hood.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
No issues under the dash.
Reactions: BigOL3
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Started on the alignment last night. Gonna need to do it again with less alcohol involved and more patience. I know the tie rods are supposed to be adjusted the same, but with the steering wheel straight one tire is toed out more than the other.
A3764ED3 8947 4BD5 A65C 6C76F476F01C
2fbc16c8752547b92a642a19479b971e
lee
lee
Village Idiot
2,331
13,073
Springfield Ohio
In order:
1) center the steering rack (at the rack not the steering wheel).
2) set the toe, there are 3 parameters to play with : tires straight, tie rods set about equal and rack centerd.
3) recenter the steering wheel - the center cover pops off and there is a big nut holding the wheel on. The wheel is on a splined shaft, pull it off and put it back on as straight as possible.
4) now crack open that first beer.
E
elkguide
3,377
7,963
Vermont
In order:
2) center the steering rack (at the rack not the steering wheel).
3) set the toe, there are 3 parameters to play with : tires straight, tie rods set about equal and rack centerd.
4) recenter the steering wheel - the center cover pops off and there is a big nut holding the wheel on. The wheel is on a splined shaft, pull it off and put it back on as straight as possible.
1) now crack open that first beer.
Why did you post them out of order numerically @lee?
Reactions: lee
lee
lee
Village Idiot
2,331
13,073
Springfield Ohio
Wrenching is different than riding.
Riding you drink and suddenly that hill or rock or mud hole doesn't look so big.
Then, mysteriously, something breaks. (I'm sure it was some how Hondas fault)
Now you need to wrench.
You don't want wrenching to look small or easy - if it where easy there would be no accomplishment to Bragg about later.
With out something to Bragg about the whole premise of the HondaSxS.com club would cease to exist.
chadbo
chadbo
Mama tried
2,044
5,658
Seminary , Ms
Without beer many of us would cease to exist
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Got some new lights on. Liking how they turned out.
Nicoko RGB lightbar and pod lights.
Reactions: Tigermark and BWAF
