Need some suggestions on how to drain the front seat. Went 4 wheeling yesterday through a lot of water and then cleaned it when I got home. The front seat is heavy with water. Any thoughts on how to get rid fo it? Thanks.
Maybe hook an air hose in one side and let it blow thru for a while. You could take the end off an air hose so it will flow freely with out you having to hold it. Then turn down the regulator to a much lower pressure like 20 psi or something and let it go for a while.
Of coarse this requires a decent air compressor to do this. You could also use a inflatable toy inflator to do the same thing.
