Is it possible that the 2018 version has a different secondary battery compartment? My 2018 doesn't look like some of the pictures.
I haven't even bought the battery yet - just trying to figure out what I need to buy.
Assuming I'm not running anything but the UTV with a winch, do I even need to worry about a secondary battery?
What happened to me was when I was plowing snow, was if using the winch to raise the blade, started to change directions the clutch would not engage. I talked to the dealer b4 installing the winch, and got there quote for price, the dealer recommend a extra battery because the winch draws a lot of amps, which can cause the voltage to drop to much,and can cause issues. I installed the winch without the extra battery, and had issues. I installed a factory replacement size for the extra battery with the Tru isolator. After doing this no issues. I have been using winches on ATV's for 20 yrs with stock battery, and worked ok, but those were 1500-2000 lb winches, I have a 4500lb now, it draws more than twice the amps, I believe this is why only one battery is not enough, plus there is alot more electronics now.
