If you don't want to run a fuse panel and separate relays (for each accessory that needs one), you can use an Auxbeam 8-gang switch unit. The Auxbeam unit is compact and, once installed, makes wiring new accessories a breeze, as it has 8 relays and fuses internal to the unit. After installing, all you need to do for each accessory is run power & ground to the Auxbeam power unit.
If/How you run a CD relay/key-on/DPDT switch to power the Auxbeam is still up to you. I actually have both on my Pioneer, as I found out about the Auxbeam after wiring up most things the other way. My '23 Talon will start with just the Auxbeam (and CD/key-on/DPDT switch) and only use standard Carling switches & relays if absolutely necessary.
Auxbeam panel on Amazon (also
available on our Club store - it costs a little more there, but it does support these forums)
Extension cable for panel if needed
