As like most of us with dual batteries, I’m using the True Amalgamated dual battery isolation setup on my 2018 1000-5 LE. I have a Warn Axon 55-S winch, and other than an MTX sound bar, it’s the only accessory utilizing the accessory battery at the moment. I have an Autozone Duralast battery for accessories, and the factory battery for the main systems.
My issue is that the auxiliary battery voltage seems to drop faster under winch use load than the system flips over to feed the auxiliary battery for, so the winch stalls out due to lack of power. Once the main battery charging is satisfied, it kicks over to the auxiliary charging and temporarily fixes the issue.
Questions:
Should I change the auxiliary battery?
Should I put the winch on the main system battery?
What am I missing?
Thank you for any advice!
Questions:
What am I missing?
