P700 Dust in cab
hondapro
hondapro
39
83
Central Pa.
I have a 700-4 with the Honda glass windshield and the Honda hard roof,I am getting alot of dust when riding dirt roads, I have the fabric rear panel that helped some.
I was wondering if I remove the rubber seat from the top of the windshield frame if it would leave enough air in to help with the dust?
I know the real fix is to buy a new windshield that can be opened,I am just trying to avoid spending another 500.00
Reactions: ByronM
Backwoods
Backwoods
35,776
362,054
Douglasville ga
I have a rear panel they help but I won't run it in summer time. My 2 piece windshield seems to help a lot when it open. If it was was not for the wife liking it I would not run windshield this time of year.
Gator
Gator
The Most Unknown Member
2,488
10,464
Louisiana
I finally just removed my windshield.
Dust is a big problem and it is not just the Honda.
Reactions: Mudwing
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
just got get a peice of lexan for the warm riding times. make a half windsheild put a little lip in it with some 2x4s and clamps and either a torch or heat gun. i took my top 2 clamps off the full windsheild and used them to mount the half.
Badblubug
Badblubug
175
356
North woods
I had the same problem with dust in my p500 I was running a back panel, hard roof and tilt windshield, this summer I pulled the back panel off, Bimini soft top and 1/2 windshield installed and 75% less dust
Jacob715
Jacob715
12
19
MO
I just removed the lower of my 2 piece windshield and that helped a bunch. I also ordered some extenders to open the upper windshield more.
L2R
L2R
Understanding women Vol. 1
1,063
6,599
East of the Appalachians
A full windshield pushes the wind left and right.
It then circles around and comes in from the side and rear (just like you have seen rain in a big bubble behind a semi truck on the highway)
The rear panel stops some of it but you there are still in the middle of the turbulents swirling around like the spin cycle of a washing machine.
The best way to stop this is to remove the windshield altogether in warm weather.
A half windshield still allow some air to flow straight thru and a lot better than the full shield.
I guess it depends on where you live and how you use your sxs.
I best answer is a cheap fix, a $10 pair of sunglasses.
Then spend a little effort on some way to hang your windshield in the garage or shed when not in use.
All opinion of my limited experience and what I have read of others who have had success and failures. No wind tunnels or blue smoke was used in the making of this post.
