P1000 Eating Front Tires
russknight
russknight
1,910
7,511
Perry Florida
As title says, my 1000 is eating the front tires. I used the string method to get an idea where the alignment was. Passenger side was toed out about 3/8 - 1/2". Adjusted it to where it now has a slight toe in, drivers tire is parallel with back tire. Didn't seem to make any difference. Any ideas?
Reactions: BWAF
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
My toe was 3/4 off ,cousins work 1000 was 1 1/2 off something that needs checked on new ones !!
It's a good idea to check the alignment several times in the first 1000 miles as the front springs settle. You'll probably find it needs a bit of adjustment each time
0860silverado
956
1,845
louisiana
Yep. It seems most or all P1Ks come from the factory this way. Some theories suggest that Honda does this by design to make the machine more forgiving against rollovers when making aggressive turns. After mine ate my front tires in a matter of hours, I aligned it using the string method with a 1/8" toe in on each side (front centerline of front tires measures 1/4" less than rear centerline of front tires), replaced the front tires and I've got about 6,000 all asphalt miles on my Tusk Terrabites with a couple thousand miles left in 'em.
P.S. I noticed no difference in handling characteristics after I made my adjustments either. It just makes the tires last as they should.
russknight
russknight
1,910
7,511
Perry Florida
I'm thinking about going with the Terrabites. Less than 10,000 miles of tread life is a little concerning though. What size are you running?
Reactions: BWAF
105,595
Ff 4841 600x621
0860silverado
956
1,845
louisiana
Stock sizes. 27x9-12 in front & 27x11-12 rear.
A
Average_Joe
955
3,539
Gainesville, Fl
  2. Other Brand
Why not go with a light truck tire I swapped to a 235/75/15 I have 128 miles so far the ride has improved with night and day difference.
Reactions: russknight
russknight
russknight
1,910
7,511
Perry Florida
Anyone running 30's? Comments?
Fit's stock wheels? Are they any taller? I'm wanting to lower my rpm's at higher speeds. I'll be driving a lot on pavement.
A
Average_Joe
955
3,539
Gainesville, Fl
  2. Other Brand
I had to buy 15in rims but I have less than $500 for rims and tires. I'm running Forceum light truck mud tire they look to be 29in tall they are smooth i would recommend getting them balanced at 50-53 i get a vibration it goes away at 55mph and faster. The price has went up on my setup you can get my tires and rims for $500
https://www.amazon.com/gp/product/B017OF96G2/?tag=sxsweb24-20
https://www.amazon.com/gp/product/B07NGJRFBZ/?tag=sxsweb24-20
russknight
russknight
1,910
7,511
Perry Florida
Do you have any pictures of them on your ride?
A
Average_Joe
955
3,539
Gainesville, Fl
  2. Other Brand
I'm at work I had to find the thread on LT tires. Second page I have the highlifter 2.5in lift the rest of my suspension is stock a-arms and shocks.
P1000 - Tires and Wheels
russknight
russknight
1,910
7,511
Perry Florida
Here's the drivers side front tire with under 400 miles on it.
Tire wear
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
Did you ever check the alignment? Odds are it is visibly toe out. I know its easy to blame the dealer but in the end you own the machine and doing a simple walk around inspection before riding should have shown you the alignment was way off
russknight
russknight
1,910
7,511
Perry Florida
According to the string method it is not toed out. And where did I blame the "dealer?" I bought the machine used. Perhaps you should have read the first post in this thread.
ToddACimer
ToddACimer
Pioneer 1005-2
3,685
15,587
Oshkosh, Wi
What was the measurement front and rear?
russknight
russknight
1,910
7,511
Perry Florida
I don't recall. I adjusted the front to the measurements above. I have SATV arms for the front. After installing them, I'm going to install new wheels and tires and have it machine aligned. I think I read somewhere it should have a 1 degree negative camber with 1/4 to 3/8 toe in. Is that correct?
