P1000 Ecu Reflash for cooling fan? Or is it more!
175
493
Kansas
Are there any techs on the forum who would be willing to do the flash for those of who aren’t fortunate enough to have a willing dealer?
SikorskyGramps
SikorskyGramps
98
245
Castlegar, B.C.
I have a 2019 1000-5 we put tracks on. The second day we had it, it was idling in the yard and burped out coolant as it overheated. It did it two more times on a 20 degree day while traveling over the snow at around 29 mph. Each time it overheaded. I noticed the fan did not come on. I called my local dealer and was told to bring it in the next morning. I didn't even take it off the trailer. The tech. met me in the parking lot and did the flash. It has not overheated since. I also installed a fan over ride switch just in case. I didn't have enough time in it to notice if it change the performance.
I have a 2017 P1K-5. Lots of mountains around here and it immediately started overheating after 20 mins of climbing. Sometimes I would get 4 bars and a light, but many times it showed 2 bars and no light, while it boiled out the overflow (sometimes with the fan running, sometime not) Honda had no clue, it was this Forum that had the answer: park it on a 30 degree nose up slope with a cold engine. Pull the rad cap and idle it until the fan comes on. After several huge burps the problem was fixed. Apparently Honda doesn't take the time to properly bleed the system at the factory. The bleed procedure in their shop manual is garbage, tried it twice and didn't help at all. I still hit 3 bars on a long, slow speed climb, but it has never boiled again.... Will check into this Flash procedure, hopefully can be done on the 2017. Thanks all!
Reactions: 2018GMC and TripleB
Capnray
6
Crystal Falls, michigan
The dealer will have to do it. Just tell them your having cooling fan problems and mention the reflash.
I've been doing every 1 that comes through even if the customer hadnt requested it.
Is there a reason why the re-flash can't be done on the 2016 models?
Crockett
Ca
I called my dealer today and they said this new flash was for the Talon. Thats probably why it is not for 2016 or older. It might also explain why those that have had the flash now have more lower end torque and a different shifting pattern. They are now programmed like a Talon! If you add the after market turbo to your Pioneer you will have a hybrid....... We can call it a Taloneer!:D
HondaTech
Well their full of s***.
Crockett
Ca
I concur since the service bulletin says nothing about the Talon, only the 1000M models which Pioneers are. However, could the re-flash be designed for the Talon, therefore causing the change in shifting and such?
Tramguage1
Tramguage1
Texan
7,528
30,949
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
The Talon wasnt even out when the flash update became available!
HondaTech
I doubt it, just some dealer who makes up s*** that sounds good.
HondaTech
If you were closer, I'd do everyone I could get my hands on.
I'd say its possible to swap ecms and update it through the units wire harness, then install the updated part back into the original machine.
175
493
Kansas
So you’re saying you could reflash mine if I sent it to you?
HondaTech
I've never tried it this way, not sure if this would actually work.
175
493
Kansas
I’m assuming that the reflash is done through a data/com port located within the wiring harness vs. a stand alone diagnostic tool that plugs directly into the ECU?
HondaTech
Yeah it's the red 4 pin under the seat.
I talked to my GM, he said that he thought the ECM swap should work.
If someone was willing to pay shipping both ways, we could try one and find out.
Reactions: CumminsPusher
175
493
Kansas
Shipping info?
I’ll send it out Priority on Monday.
HondaTech
Shipping info?
Honda Of Fairfield
5467 Dixie Hwy
Fairfield, OH 45014
I need VIN and mileage from the unit as well.
How do you plan on paying for shipping back to yourself?
dnjones161
dnjones161
583
1,713
Ohio
Honda Of Fairfield
5467 Dixie Hwy
Fairfield, OH 45014
I might have to give you a ring a schedule this. HoT told me there was no update last week when I had it in for the gas peddle recall.
You are maybe an hour down the road from me, but that would be worth it from what I'm reading.
HondaTech
Give us a holler, we'll do any update/recall Honda is offering if your unit needs it.
tincangob
tincangob
200
270
Central Wisconsin
I have a P1000 2018 model and have not received any tech notices, other than a recall for gas pedal potentially get stuck or something. I have however overheated when climbing big hills in low for extended period of times. As such I always watch the temp and if it hits 3 bars try to get to more level area for a while in high to let things cool down. Living in Utah though, got lots and lots of mountains to climb.
Ditto with my 2018 .... no problems with normal driving.
Outacntrl
Outacntrl
111
326
Kansas
Well my crappy dealer strikes again... The service adviser said he is 100% sure this reflash won't fix it and then told me it didn't even apply to my VIN. According to the bulletin posted it applies to ALL 2018 VIN's. I reluctantly had to leave the machine there, I will update tomorrow when I pick it up. Unfortunately I have no way to determine if the software actually gets updated other than if the drivabilty is drastically different. Anybody know if SCT Pro or HP Tuners software will read anything? I also have a buddy that has HONDATA. Maybe it will communicate with it?
