Electric pressure washer
TxDoc
TxDoc
1,617
5,614
TEXAS 🇨🇱
photos.app.goo.gl
I've got a gasoline powered Honda 3000 psi pressure washer.
I'm looking for an electric pressure washer that I can keep in the shop, quickly carry outside, set up and go.
I'm wondering if anyone uses a 1500 psi with around 1.7 gpm flow?
Looking around, Sun Joe send to get high ratings on most models.
Looking for input.
Thank you
Reactions: Mudder and JenElio
O
oldfortyfive
595
1,316
Illinois
Stihl has a little one that is pretty good. Reminder, even at those lower pressures don't let the nozzle near your body parts.
56,701
I have the same small Ryobi @DDDonkey mentioned. I've also got the Harbor Freight one they put on sale for $64.99 pretty regularly. I use the wand from the Ryobi in the HF washer when I use it since the HF wand tip is just two plates that press together versus an actual nozzle.
319,689
We bought a little Ryobi as well at my work as a backup to the gas unit that went in for repair. It’s been fine so far after 4-5 months, in fact even though it doesn’t have the power of gas we’re still using it for washing cars. Works better for our situation.
rickoshea
i have a 1900 psi simoniz i got on sale as it was being discontinued and surprisingly it still works after a year and a half of hard use, and came with the foam nozzle.i prefer the electric over the gas for my needs.if i need 3500 i grab one from work.
Reactions: Mudder and TxDoc
CajunRedneck
CajunRedneck
54
150
Southeast Louisiana
