P1000 Electrical Help
Calvin
Calvin
42
Benton, La.
I've got a pretty good view of that mess of wires looking in from cab through hole I cut out of warning sticker where I'm mounting my switches and Bluetooth controller. I'm like you though don't know if I want to start peeling away all this tape. Can get to the two wires running to cig liter though may just tap into that like your taking about.
Reactions: Everett
16Honda
16Honda
35
45
With all of the accessories out now, you would think they would make it a little easier to get keyed power. Most people won't use the Honda accessories only.It would be nice to raise the hood and see a marked accessory connection.
Reactions: Hometeam
BigRiver
BigRiver
324
79
I'm disappointed to say, but it looks like the truth of the matter is that Honda wants the consumer to buy the accessories only from them.
It's not impossible, but sometimes challenging, depending on the individual, to accomplish the addition of aftermarket accessories.
Reactions: Mlm and Hondasxs
Johnny_C
Johnny_C
303
143
Western N. Carolina
I don't know if you guys read
where I have decided to power
my solenoid with a hot from
my aux battery. I will activate
it with a switch on the dash.
With that config, I don't have
to get into the factory wiring
at all.
John
Scooterchris
No longer active.
Dec 25, 2015
396
237
I was told today that my current setup (one 42 inch OPT 7 light bar and one little 8 inch OPT 7 bar can be run of the same provided relay and off the same mictuning switch i bought off amazon. Is this true?
Info as follows
42 inch bar- 240 watts/20amp
8 inch bar- 36 watts/3 amp
(Both running on stock provided wiring harness and relay)
Mictuning L.E.D light bar switch of amazon- 20amp/12v​
educ8tedguess
educ8tedguess
403
972
Spring Grove Illinois
  1. Looking to buy
I had this same thought when installing my plow last night. I have the KFI winch mount and bought the plow from Honda. The mount plate took some effort to get on because it wasn't fully compatible with the winch mount. I got it figured out but it was one of the more difficult mount installs I have done.
Calvin
Calvin
42
Benton, La.
Could you not just use one of these fuse taps and insert it in your acc fuse location in the fuse panel to get switched power? For use on like your lighted switches. That way you don't have to splice any wires?
68,239
@Calvin.
Maybe! If there is room under the fuse box lid for it I dont see why it would not work.
I've used them before and had the same thought. Is this ok? Looks like a fancy redneck fuse tap. They've never given me any trouble though.
I'd be careful using this, you're adding a load to a circuit that may not have been designed to carry it. (Too small of a feed wire) Hate to see a nice pretty Honda go up in flames like this
3e8968eacdfc78ff3bcb644ef62f967e
Good note @ohanacreek. If using this method to power a an accessory thru a relay, I would say it's ok. But if you ad an additional 5+ amps, not good.
Joe
Calvin
Calvin
42
Benton, La.
Thx for heads up on that @ohanacreek. I just read where it's only rated for 10 amps max not sure how many amps those small led's in those rocker switches pull but probably not worth the risk.
68,239
@Scooterchris, theres no issue running multiple items off the same relay. As long as you do not over amp it. But at 23amps you should be fine. The switch is irrilvent as it should just control the relay.
Wait... Are you saying you just tapped the stock wires and relay to power these lights?
Scooterchris
No longer active.
Dec 25, 2015
396
237
No sorry I meant the stock wiring harness that came with the light bars.
Just wanted to hook them up on the same switch and same relay if possible to reduce all that wiring
Reactions: Hondasxs
N
Ned
241
183
West Kentucky
I have decided to use the Universal bus/relay shown earlier in this thread. I see that both nbomar and CumminsPusher have placed the in the same location.
Have you guys found any advantages or disadvantages to that location
? Has anyone with that same piece of equipment chosen a different mounting place?
I am just about to start drilling holes,screwing things down and running wire, so I thought I would ask where others have installed this unit?
