Talon Engine crankcase vent tube
U
UPSMAN
16
North Carolina
Has anyone run the crankcase vent tube up to the height of the air box or is there any worry of water getting sucked up in the tube
Code54
Code54
585
635
Hurricane West Virginia
I have not looked at it closely but does it have a 1 way valve on it by any chance?
lee
lee
Village Idiot
2,443
13,833
Springfield Ohio
Maybe I'm confused, but I thought the crankcase vented in to the air box?
If that is true, then getting water in the crankcase is not the issue, hydrolocking the engine when the cylinder fills with water is the issue.
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
I'm with lee on this one. Not really sure what you are referring to. The crankcase breather comes out of the top of the valve cover and goes into the filtered side of the air cleaner housing towards the top. If you have water to that point, you are in big trouble.
If you are talking about another vent line, please post a pic and let's see if we can help you determine what vent line you are talking about.
Maybe he's referring to the Sub Trans?
Code54
Code54
585
635
That is the one I was thinking he was referring to. It ends down by the skid plate area if I recall correctly. Cant recall if it has a one on it or just a open hose.
68,423
The hose at the skid plate is the water pump weep tube. It's designed to leak instead of pushing coolant into the motor.
Reactions: IDIOT and 70Bones
Code54
Code54
585
635
Got ya - thanks. I recalled seeing one there but cant say I really paid much attention to it. Was busy changing out the skid plate at the time. Thanks for the info.
