P500 Engine light overheating coming on
N
Nlviking
22
68
Canada
Hello all,
ihave been watching this forum for a while - lots of info. Just ran into a problem
I have a 2017 p500 and I decide to change the coolant. I followed the instructions passed along in a earlier but the bleed valve as in the image was not on my 2017 model. I had to haul the entire seat out pass the seatbelts. you can find another valve there which released air when I unscrewed the nut.
thinking this was fine I decided to go for a ride. Only about 3 km into the ride the fan came on and the overheat light came on. ts only 5 deg Celsius here.
any thoughts. Would air in the system be causing this..
thanks
66,821
Hi,
Since the fan did come on...
Then ya, most likely still air in there.
Find a very steep but short incline. Like almost climbing a wall.
Leave the cap on and run the front up the wall and hold for a few minuets.
This works on the 1000 for moving the air pocket.
N
Nlviking
22
68
Canada
Yes my apologies. Thanks for the advice and help.
FE8C7D50 C845 4CB8 BAF8 8E77AEF64061
