Engine oil refill amount
F
fartsalot
223
337
Near the Kansas Nascar race track
If I'm reading the manual correctly when replacing both oil filters the amount of oil is 6.1 oz,,,, right? 6 quarts and 3.2 oz ?
Twice I have changed the oil and after I put in 6 qts and 3.2 oz of oil and let the engine run for a few minutes and shut it off and let it set for a few the dip stick shows no oil on it. So as to not over fill the engine I added 4 oz and did the run and set routine and still no oil. I have ended up adding 16 more oz of oil and now I have oil on the tip of the dip stick. I let it run and set for a few minutes and let the stick sit in the hole (not screwed in) when I take the measure.
Has anyone else endured this?
Russ989
Russ989
22,642
147,257
Yes I have, mine always takes a bit more.
IDIOT
IDIOT
280
755
Kingman, Az.
My Yamaha YXZ is the same way, you just never know how much oil it will take to get it to the upper fill line on the dip stick. Even though i use the same oil and drain it in the same manner.
Reactions: Tedbell52
Bobrhino
Bobrhino
37
101
Arizona & Nevada
Same here with 2017 Pioneer 1000. Always add more with oil and filters change. About 3.2 oz with older clutch cover, nearly 4 oz extra with newer cover. Always allow hot oil to drain along time, though not sure if it matters.
PaulF
PaulF
1,462
4,814
6 qts, 3.2 ounces is correct.
Mine did something similar and then I realized I was overfilling the engine. It was cooler weather and if I didn't let it warm up completely (2 bars on the temp gauge), then shut down and wait a full 3 minutes, it would take more oil (not that I remember an additional 16 ounces but it was quite a bit).
Now I completely warm it up, shut down and wait a full 3 minutes before checking and 6 qts, 3.2 ounces is always enough to fill after an oil change. Fills it right up to the full mark.
You may want to check again. First, make sure you don't have any leaks. Then make sure it is fully warmed up (maybe even drive it around a little), let it sit perfectly level for 3 minutes and check again.
Reactions: TripleB
5,425
24,913
This procedure makes me krazie. :oops: Why didn't they just provide a dipstick with the proper markings for reading a cold engine? Simply pull the dipstick from fully seated, before starting and check my oil? The recommended way has too many variables, how many guys even wear watches any more? When I'm tinkering in the shop, all I want to do is check my oil, not start it up, wait for it to reach 2 bars, time 3 minutes, burn my fingers, check oil and wonder if I got it right. 🤔
My solution, about 1/2" above the flattened end when cold.
I Jv4qKHq XL
PaulF
PaulF
1,462
4,814
100% Agreed! I mainly only use the factory method at oil change, after a hard ride or if the engine is not stone (overnight) cold.
Otherwise, I try to park level after the last ride of the day and use your method before the first ride in the morning.
Reactions: TripleB and CID
