P700m4 Engine oil?
Brentc
Brentc
71
67
SE AK
Don't know if there is a thread already tapatalk search does not bring anything related to oil up.
What oil are you guys running? Are you guys running Syn , mix, or Dino? I just finished the break in and bought regular Dino oil.
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
I would say first two oil changes use Dino, then use synthetic from there on out. I use Honda synthetic, it really smoothed out shifting
Reactions: Brentc
Brentc
Brentc
71
67
SE AK
Do you guys use MOA, Lucas or any oil adder?
I used lucas oil in the transfer case and differentials but my engine has nothing but Honda branded oil in it.
Reactions: Tflynn
Brentc
Brentc
71
67
SE AK
Yeah for the diffs and t-case I use Redline fluid with the adder for lockers in the pick up. Engine oil I use BG products MOA oil adder. This being my first sxs or single cylinder 4-stroke motor not sure if full syn or any other adders damage or help it.
SEW
24
16
Will using Honda Syn adversely affect the transmission clutches? So far, I'm just using Honda 10-30. Usually, integrated transmission/engine oil requires oil specific to that usage. My understanding is that Honda Syn 10-30 is for separate trans/engine crankcase. In the 700, they are together: correct?
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
I have been using Honda full synthetic 10w-30 for the last year or so (probably 3-4 oil changes) and I love it. No adverse affects actually makes the tranny shift smoother.
Harman24630
Harman24630
283
493
Tazewell Va
I've only changed mine once so far but after the 100 mi breakin service I went with Rotella T6 10w30. Seemed to shift a lot smoother and it runs cooler not noticeable on temp gauge but the fan don't kick on as much. I realize this could have been from it breaking in to but when I reach the 600mi mark I'll use T6 again.
swsebek
swsebek
2,854
5,835
pa
same here...
bigbruse
88
37
va
Anybody use the amsoil 10w-40 synthetic atv/utv oil. If so what do you guys think? I mostly just run my 700 in the summer never use it in the winter to 10w-40 I would think should be fine right?
Lynn1130
Lynn1130
126
171
Phoenix, AZ
I use Amsoil but only 0W40 ATV/UTV. That is what Amsoil lists as an alternative for the 700.
Everything I have that has an engine has Amsoil in it.
Reactions: bigbruse
ckhenshaw4
176
81
Same here. After break in, I have run Amsoil 0W-40 full synthetic ATV/UTV oil. I use Amsoil in front and rear diffs also.
Sent from my Nexus 7 using Tapatalk
Reactions: bigbruse
Lynn1130
Lynn1130
126
171
Phoenix, AZ
Me too and it could be my imagination but I thought it made less noise with the change.
Reactions: bigbruse
wyo700
wyo700
413
210
I know when I switched to Honda syn after first change my engine got quieter also shifted smoother. Changed rear end to Mobil 1 syn and it also got quiet. I have used syn in every vehicle I have ever owned and I am a true believer.
Reactions: Tflynn and bigbruse
