Engine stalling while driving
Dallintcoleman
5
11
Arizjba
I have a 2021 Talon fox live valve and when I am driving after a while my oil pressure light turns and and its stalls my engine and I can’t start it until like 30 minutes after. I’ve been told to get a new iacv but I’m not sure if that’s the right thing.
Does anyone know what the problem is?
Reactions: TxDoc
115,405
First off, welcome from Michigan
Need Pics of your rig. Its rule#4 and will help u go further with help.
Now your rig. Have you checked your oil level? They've been know to come low or without believe it or not.
And WTH does a nee jack have to do with all this?
  • Haha
Reactions: -Bear- and TxDoc
Dallintcoleman
5
11
Arizjba
I’m sorry auto correct took control. I meant iacv, idle air control valve.
DRZRon1
DRZRon1
1,199
3,872
PA
need more details, such as miles, crap u added on and if it’s been submerged, rebuilt, a road queen, etc…..
when u say u can’t start it - it won’t crank over or it endlessly cranks and no fire, etc.
does it idle ok - what does it mean u are driving awhile ? Just cruising along a normal flat trail and machine shuts off
Dallintcoleman
5
11
Arizjba
It’s got 2700 miles on it, it’s pretty much stock. It endessly cranks with no fire. It idles fine at about 1000 rpms. It’s turned off while driving a flat dirt road and just cruising down the street in my town.
DRZRon1
DRZRon1
1,199
3,872
PA
Hi - thanks
I would go over every battery and power connection and have battery load tested. Guessing here but fixed many machines with that symptom and all were loose battery terminals - what CID said
Reactions: CID
Dallintcoleman
5
11
Arizjba
Cool! We will b waiting!
Check and CLEAN all your grounds good
IMG 2196 IMG 2195 IMG 2194 IMG 2193 IMG 2192 IMG 2191 IMG 2190 IMG 2189 IMG 2188
