Talon Engine vibration
Daveb6618
7
Wv
Put 140 miles on our new talon and I loved it but I did notice it has some engine vibration at around 1.5 to 2 k rpm. Above 2k it goes away and is smooth. It does this in neutral and High and low. Drove two different ones at the dealership, a red one and a blue one both X's and they both did this. I read it does this because of the way the engine is mounted to the frame and how big the cam is and all the torque the engine makes. So is this true and a Normal thing ? Or am I the only one experiencing this?
Mikehallad
Mikehallad
29
24
Highland, Utah
I have 134 miles and I feel some roughness at start up but not after the initial start. I will pay more attention to the rpm and see if it is similar.
PaulF
PaulF
1,462
4,810
This is normal. The Talon has a 270 degree crankshaft instead of a 180 so it is not an even fire engine. This is mainly done to increase torque. It fires similar to a V-Twin engine.
This can cause a type of vibration at certain lower load, lower RPM as you have noticed.
NemoDeven
NemoDeven
44
61
I have noticed in low range when engine braking going down a steep grade the most.
PaulF
PaulF
1,462
4,810
Almost makes you think the engine mounts are loose or you are sitting on a Harley D never noticed this to before with my Pioneer 1000 so the 270 degree crankshaft must be the difference.
Harleys are actually a 315 degree motor so the vibrations are a little more prevalent but create that unique Harley exhaust tone.
Not sure why you don't notice it in the P1000, it is also a 270 degree motor just like the Talon. Maybe the Talon requires a little stiffer motor mount that transfers the vibration a little more.
Yamaha (allegedly) pioneered the modern day parallel 270 degree engine in 1995. It was designed to mimic the V-Twin "sound" and have more power than a 360 degree and less vibration than a 180 degree parallel twin.
It is thought by many (including Yamaha, Triumph and now Honda) that the 270 degree parallel twin motor is the best compromise between power, vibration, sound and cost. I assume that is why Honda is using it in the P1000, African Twin and now the Talon.
O
OrangeTalon20
6
NH
Hello, this is great information thank you. I just bought a 2020 Talon 1000X-4 live valve and notice the vibration at 2K. I called the dealership and was told they never heard of this. I bought the Honda as it should be bullet proof. The vibration concerned me.
Dankathy
286
822
In my experience it is uncommon to have a problem that my local dealership has ever heard of. I gave up on them.
5,028
22,469
Mine in neutral shakes badly between 1500 to 2000 rpm I don’t get it
Welcome from the once great state of Colorado. :cool:
Check out the link in my sig for some basic Talon information if you haven’t seen it. It’s also a sticky in the General Talon 1000 forum, making it easier to find - New Talon Owners - First Things to Know and Check.
One of the posts will link you to the driveshaft issues.
bstover1986
Arizona
Welcome to the forum!
Got pics of this Talon, what one do u have, yr milage?
Pics Or It Didnt Happen!
Search Talon Driveshaft
It’s not the drive shaft it does it in park also
D5E78BE4 1DD6 4912 8351 5BDF2083D051
bstover1986
Arizona
Its normal, torque of the motor and supposedly it is on rubber mounts, they all do it.
I was wondering if I should replace the motor mounts they got 13,000 miles on them and by the way idiot your not gonna believe this but I had your old yxz. I put the 2019 roll cage on it.
2B13A0EF 9E1B 4D98 9617 7DAA0E6372D8
