P700 Excessive toe-in
M_Walker
15
32
Our OEM tires were wearing quickly and weren't the best choice for the terrain we drive on. It's mostly hard packed dirt roads, two tracks, and pavement. I installed new Tusk Terrabites, 27x9-12 front and 27x11-12 rear. During the first ride with these, the steering felt like it wanted to pull one way or the other instead of holding a straight line. The OEM tires might have felt like this a little, but it wasn't as noticeable.
I checked the alignment and found it was toed in 1.25"! This machine has very low miles on it and has never hit a big bump or pot hole. I set the toe-in at 1/16" and it now drives down the road straight and true.
i had previously read posts here and other places about people finding their alignment off from the factory. I'm certain ours was always off and just became more noticeable with new tires. I would encourage everyone to check their alignment. Even on a new machine.
Tomcat61
Tomcat61
5
22
Moncton
I got my 700 a month ago, and checked the alignment and mine was out by at least an inch,,, my first trip out I noticed when starting out it was pulling to the right , Glad I checked it,,
Reactions: M_Walker
Tuk-Tuk
0
Texas
Please share how you adjusted the toe on your 700, thanks
Mopower58
Mopower58
Unburdened by what has been!
86,606
747,394
Crystal Springs,Ms.
Most of the P1K's sold were toed out. Supposedly to make them more stable on gravel roads.
210,947
Pulled a string line down the center of the machine and adjusted?
M_Walker
15
32
I marked a spot in the center of the tread on both front tires and measured the distance between spots when they faced forward and also when the same spots faced rearward. I then adjusted the tie rods until there was 1/16" toe-in and the steering wheel was centered when driving in a straight line. I got lucky and only had to adjust one tie rod to accomplish this.
