Extreme Metal Products - EMP Rear Bumper
67,170
Bad news. The rear bumper will not work on a P4!
It hits the roll cage and will not let it dump 100%
So if you have a p4. Hold off until a new bracket is made, however, I will be mod'ing the bracket to fit.
More info to come once I get a plan together.
8u8ajyqu
sksshooter
79
Re: Extreme Metal Products
wow isn't that great. I have a p4 and a not only a bumper without bolts but it doesn't fit if I did have them. Love it
67,170
I sent them a email.
sksshooter
79
How far is the bed from full tilt?
67,170
A lot.
sksshooter
79
Thanks. I was thinking just notch the bracket. I don't know if there would be enough material left if you did that.
sksshooter
79
By the way how difficult was the install? Seems like a pain to pull the bed apart but I haven't looked at it yet.
67,170
It was fairly difficult. Had to apply a bit of heat and use a impact screwdriver set to get the Philips bolts out. The door hinge bolts were kinda tough also. But I got them all out.
And yes, you must do both sides which sucks.
67,170
Made a bracket mockup and sent it to EMP. See what they make of it.
hurld
hurld
129
159
Hondasxs when EMP sends you new brackets if you don't have to send back your old ones I would be willing to buy them from you for a fair price. I was going to fab my own brackets similar to your cardboard template, but I would have more time into the brackets than my custom bumper.
sksshooter
79
just got off the phone with emp. they will not be re-fabbing these brackets. they offered to send me a shipping label to send the bumper back. i told him i would like to hold off because i "might" be willing to modify the brackets myself. i asked what he could do for me if i opted to just keep it and modify them he said he could send me a couple of t-shirts or refund me $20. told him i would call back in the next day or two and let him know my decision.
67,170
Well... That sucks.
Maybe they already punched out a lot and will have no choice but to make a bracket.
sksshooter
79
hondasxs on your mock bracket how much material did you have left above where you have it notched? I am going to keep it and cut the brackets. once cut I will weld a piece of angle iron on the cut side for re-enforcement and slap some paint on it. from the measurements I pulled I can keep just over 1.5inches of material. I will probable cut it to 1.25" and then back it with 1/4" angle.
really kind of pisses me off that they won't fix the problem instead they are just going to only supply p2 bumpers. I need some fast straps so I'm going to see if I can't get some of them for the trouble and then ill be done with emp.
67,170
That's what im going to do too. Give me a few and I'll measure it.
67,170
Keep the width of the mount point. 1.25 inches. Remove 4.5 inches inward.
All are from the rough mock-up so I can't say it's 100%, but it did clear the ROPS in cardboard.
May be next week b4 I have time to work on it. I will be posting my work.
sksshooter
79
those measurements are right in line with what I have so I'm going to cut it. I may possibly get time tomorrow evening if not it will be sat evening before I have a chance to work on it. if I get mine done before ill update on how it works out.
67,170
Yep, confirmed, got a email today form EMP. No plans to build a rear bumper bracket any time soon.
Maybe once they get a hold of a P4 they will look into it.
But good news, the front bumper has arrived.
sksshooter
79
EMP Rear Bumper P4 Modification
my front bumper was supposed to show today but when I checked the tracking it pushed back to tom. I did however get a chance to do some work on the rear bumper, mounted my new wheels and tires and got the front bumper removed so that when the new one shows tom I can mount it up.
I cut the mounts down to 1.25"
I then welded a piece of angle iron in to reinforce the plate since so much material was lost.
C895FB83 6B56 40CF AF13 0CC0980822E2 zpspk4at62x
CF919BC1 2C34 45E6 8487 DE3A23B592F9 zpszduwc1pm
I then painted them up and mounted them.
0C70C8C9 0FFF 42D1 B30C C421ECFF17F2 zpsvaxkxxth
538BCFA6 1E51 4956 835F 8423FB84BCCB zpsik30z17p
then re-assembled everything. I the driver side actually has about 3/8" space between the roll bar. the passenger side is touching but it was enough that im pretty positive I have full tilt. I didn't get a reference point prior to mounting the brackets and didn't want to remove them to make sure. looking at hondasxs pics it appears that if I did loose any tilt it was very minimal.
7B853BC8 F389 4466 848E BDA75F0BED72 zpshgdydior
25AE2329 19C8 48CC 803A 5C44BAEA384D zpspr661lgr
B319727B 1A2C 4BB5 BA98 2462F56928AA zpsxzfotoeb
my new tires/wheels 27x9-12's all the way around on itp ss312's
7ADE3BA3 A29F 4F9F AC28 FB91EDF51795 zpspfljaoxw
EEE9B7D6 87DB 4FB1 B756 846379EBB88B zpsbcpj5pds
you can tell they aren't the factory tires but they ride pretty good. they measured out to just over 27". I also cranked my rear shocks up I no have a full 12" of clearance in the rear and just slightly more in the front. now I just need to wash it, it would have been nice if it were clean before I started taking stuff apart as I had dirt falling off on me the entire time.
67,170
Good job. I found some scrap today and hope to have mine done next week.. I hope.
