P700 Final Drive Gear Oil - Still Confused
Deluxe700
Deluxe700
856
1,101
Central Arkansas
I know some folks are using the standard Honda 80 wt gear oil
Some folks using the 80W/90 gear oil
Seems like a lot of folks using 75W/140
I like in Arkansas, so not so cold most of the time. I know some folks are using the non OEM weight oil for noise reduction. And a lot of folks running synthetic.
There also seems to be some confusion if it has to be HYPOID gear oil or not.
Can anyone give me recommendations on weight and maybe even brand. I have Bel Ray 75W 90 synthetic in my tool chest but maybe I should re-think that to the 75W 140.....:confused:
motorman18
439
277
Laurel, MS
What you have should be fine I don't see why you would need anything over 90w even if you holding it to the floor everywhere you go you still only 45 miles hour
Reactions: Deluxe700
For noise reduction I used some Lucas additive in standard 80-90. It worked good.
I got burnt trying to use that expensive oil because every time I get water in it, it cost me $20 to change it. I have since fixed my issues with water entry but I still haven't switched from standard oil.
