I think I can call my accessory wiring complete for now. I'm very happy with the way it turned out. Granted I only have the Rigid Dually lights and a Warn ProVantage 4500, but I set myself up to easily wire in other things in the future. The fuse/relay box and all of my splices/connectors are weather-proof. All accessories are fused with a relay. There is a master relay and fuse for the fuse panel. I mounted my fuse panel, winch contractor, ground bussbar, and ignition power relay on a bracket that I fabbed up. I designed the bracket to be easily removed with two bolts. Once removed, the harnesses are routed that I can swing everything off to the side for access underneath. In the future, I want to build a better looking switch plate for the dash. Hope you guys like it.
