Hi all - thanks for taking a look. I was curious on what you all thought and if you can provide a recommendation. I bought a 700-4 in May 2016 with a 5 year warranty. I use it for light work around the house and some off-roading around the property. I just hit 100+ miles / 20+ hours and the wrench is displaying on the LCD. It runs very well and still looks brand-new. I can do many things myself as I am mechanically inclined and I did see a post on DIY valve adjustment. However time is a factor and spending some money to have a shop do it is not a problem, BUT I don't like potentially getting screwed. I was told by my local power sports place that it is recommended to get the valves inspected and do an oil change etc. They stated it would be 3 1/2 hours of labor at $350 for the maintenance / inspection + parts if needed. (oil change minimal). The service manager made a mention that this is a critical maintenance step and that it must be done, otherwise if something else goes wrong - Honda might say "well you did not perform the maintenance" and void my warranty etc. (something like that). If I was to do this myself, how would Honda know "I did it" etc. Is this something that "has to" be done by a certified Honda service center etc.
I'm inclined to still do this service however, may look for shops out of my area (1hr+ drive time) pending what you guys say. It just seems a bit excessive to remove some panels, screws, valve cover and perform an inspection.
Thanks for your thoughts.
Regards,
Mike
Regards,
Mike
