P1000m5 First mods
chabra
11
12
Oregon
I am looking into the first mods on my 2017 1000-5. As with all things, I have to work with a budget so mods will have to be incremental. I would like to install the highlifter control arms, signature lift kit, and then get wheels. I want to change to an aluminum alloy 14" wheel, probably increasing tire diameter to 28" or 29".
So, with the assumption that the lift kit is somewhat inexpensive, I can do that mod along with either the control arms or the wheel changes, but i can't afford to do both the wheels and the control arms, so which should I first?
Reactions: Windrock1000
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
Wheels and tires first.
if you lift it first, it will make the steel wheels and factory tire look funny.
Beauty is in the eye of the beholder, if you are beholden it is beautiful.
Reactions: pct
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
I think CFab makes A-Arms with lift built in. Might be option to check. Also, if you are doing a-arms for bigger tires, you shouldnt need to lift as well for 28-29"... i dont think
chabra
11
12
Oregon
I am mainly looking a control arms to get clearance near the tires. Also, I was under the impression that on the stock set-up 28" tires "might" rub depending on the brand and style of tire, and that 29"s would rub, but I'm not sure about that.
This is 28” terrabites on stock deluxe wheels with high lifter lift and Fox shocks= no rubbing and 14 inches of ground clearance
207EF377 493E 4876 AF91 EBDF44FA674A 6D94F270 DAC2 49B8 ADB9 04552C9CEB81
Choped5er
Choped5er
182
279
Union
I am waiting on the super ATV arms. They are the cheapest ones and in my opinion they are the best. They have camber adjustment and are offset forward and reverse. Im running 30s with no lift or arms right now. I have some rubbing on large bumps but not hurting anything. The super ATV arms are on backorder and will be here in January hopefully. If you won't want to run 28-29 I would do one or the other, arms or lift. Both would be unnecessary bind on your axles. And from my experience the stock arms are weak. All 4 of my front ones have been bent, straightend and wedled supports to, just to make it untill the others get here. I don't plan on a lift.
208,026
Hugh? I thought the Super ATV A arms were a lift?
Windrock1000
Windrock1000
2,539
9,663
Windrock, Tennessee
If you ride mountainous terrain- Trail Armor would be my first mod.
Reactions: JTW
208,026
Good lookin machine right there!
Saw some Super High Lifter A arms at the Honda shop, on some new rigs, looks as a 5 to 6 inch lift and big tires. looks like 14 inch clearance on the sides. They gave me a quote on the LE A arms, that was a joke! I'll see how my latest clutch improvement goes and go from there. They wanted $ 3,300.00 for the Super High Lift A arms, installed. Really? The LE A Arms $ 440.00 installed. Would gain maybe 1 1/2 with the LE A Arms. And have the ugly red A Arms. No thank you!
Rincon
Rincon
79
109
Yuba City, North California.State Of Jefferson
LE arms give you a lift?????
chabra
11
12
Oregon
That's
what I was thinking...do the arms...seems like the stock arms really limit the ground clearance and would be very likely get bend by coming down on a rock.
Looks really good. So are the tires 11" wide in the back and 9" wide in the front..or 10" all around? Also, do you know what the offset on those wheels are?
10’s on all 4.. I don’t know what the offset is.. they’re stock deluxe wheels, so I’m sure someone will chime in. I went the cheapest route up as I didn’t plan on adding anything bigger than a 28” tire. I will probably add some spacers eventually but if you’re buying wheels, then get your width there.
