Had a little time to play around some in the garage. Did the paint marker thingy on the dash. Swapped halogen headlights for LEDs, and mostly fixed a gap on the CEC enclosure that blasts air right into your face. The headlights are an ok improvement, good enough for $30. For the enclosure I used 2 strong magnets on each side. They were surprisingly strong. I actually did the material between them so they would be a little easier to pull apart. The 3M adhesion promoter is a must for anything you want to stick to the rough plastic. The magnets have a little double sided sticky pad to stick to the plastic and to the magnet. I will probably either paint the magnets or sew on a piece of black material to make them blend in. Nothing big, but just some tinkering.
