P1000 Flat faced lug nuts...where'd they go?
FzyMtnMan
FzyMtnMan
24
37
Palmer, Alaska
Fresh from the shipping office.......12" Delta Steel 4/137 12mm wheels holding up some meaty 27" Evo's.... got myself all kinds of amped up to mount them on this rig, got all decked out in my crummies, jacked the front of that red machine up, zipped them oem lug nuts off, loaded a new wheel on and....what the heck! I need flat faced lug nuts! Well OK, get on the ol' internet, start searching......24 hours later.....still searching.
So what say you wizards of wheels, can you point me in the right direction? Heck if you can land me on the X, I'll tell every person that I meet what a nice guy you are.
273,576
ODAMO
ODAMO
1,287
3,463
Ohio
It didn’t sink in the first time I dug this up, But :
The Honda Pioneer 1000- does not use hub centric wheels. The radius on the lugs are what mounts the wheel in a concentric fashion.
How do flat faced lug nuts accomplish this?
Robobrainiac
Robobrainiac
2,566
9,012
Typically a flat faced lugnut drives the center of the wheel over the hub and the hub lines up the wheel. On most atvs it is a very fine lip/line on the outside portion of the hub.
Under the lugnut stud you can see the lip area where the atv wheel would sit and center itself.
Atv front brake caliper rotor
You can see how the steel wheel would sit on the lip of the hub Screenshot 2022 11 03 06 32 20 50 680d03679600f7af0b4c700c6b270fe7
Lastly I just learned while searching for pictures there are dually atv kits. S l400
ODAMO
ODAMO
1,287
3,463
Ohio
That hub does not look the same as a Pioneer 1000 . I did not see any centering ring that engages the alum. wheels that came on it
Reactions: Lady01
HondaTech
You can see how the steel wheel would sit on the lip of the hub View attachment 361321
Lastly I just learned while searching for pictures there are dually atv kits. View attachment 361322
That wheels has tapered lug holes and nuts.
The wheels he is referring to are flat and use flat nuts. Basically they won't work on a Pioneer without them being off centered or out of round.
