P1000 For you electrical geniuses ....
I dont think they have always been like that tho. I know from v15 on has. We are on v18 now.
A battery is considered "charging" above 12.7 volts. As long as one (not both) is above this threahhold they should remain connected.... i think!
Once one drops to 12.7, it pulls opposite direction until both are at 12.7 for [x] seconds. Then the isolator opens and stops the bridge. Thus isolating the 2 batteries from each other.
This is what TrueAm has said about it anyways.
Got ya... that makes sense. But it seems to me you’re basically just wiring them in parallel then with the new isolators.
68,409
Yes. Thats the general purpose of all isolators. With a auto disconnect.
Reactions: CID
68,409
Yes.. It just seems that there’s less isolation between them with the newer isolators
But its not.
Battery resting voltage is generally 12.7 or less so it disconnects once both voltages reach this point. +- few seconds.
If you are drawing off a battery. The second will support the other in either direcrion ONLY IF it is receiving a charge or currently is overcharged [12.8v+].
All automatically.
So in other words.
Just hook it up and dont leave your key on.
68,409
So … you don't know me very well. ;)
There is NO solution for leaving the key on.
You can only hope
1 - you don't have your relays(stinger) set to key-on, or currently turned on.
2 - you catch it before both batteries go dead.
3 - you have a jump wire so you can pull from the second battery if its not dead.
Got that @Pilot2016
P
Pilot2016
118
173
Rockhill Sc
You can only hope
Got that @Pilot2016
I resemble that remark!!!!!😅😅👍👍
Leaving the key on is an unforgiving situation ... been there done that. Glad it happened in my garage🤪🤪
P
pukemon
tx
But its not.
All automatically.
So in other words.
did you just say battery resting voltage is generally 12.7v? if that is the case it's almost time to get a new battery. a fresh 12v battery will usually weigh in at 14v+.
Russ989
Russ989
22,645
147,291
He’s saying when the machine isn’t running, your engine has to be running to get 14+ volts.
68,409
He saying when the machine isn’t running, your engine has to be running to get 14+ volts.
Correct.
The resting/holding voltage of a lead acid battery is normally around 12.7v.
Meaning the battery in your utv after sitting overnight will be 12.7 normally. This does vary by manufacture and battery type.
A charging battery in your machine should be around 14v with no addational draw.
5,756
26,439
My '20 Talon (actual battery age unknown). Engine off for several days, key off, the VM has it's own switch.
I v2gT84s M
Reactions: Hondasxs
