No, he's relying on here say. Go read it, shock / spring set up. You should also, as well as every body buying shocksIsn't that exactly what the OP is doing, @Smitty335 ?
In my opinion I would run the OE axles and replace with rhino when needed.
I am sure the professional @SuperATV will have a good recommendation.
I don't think you understand the value of the experiences of others. IMHO, Hondasxs.com is EXACTLY the place to begin your research efforts. I never said this is the ONLY research he needs to do.No, he's relying on here say. Go read it, shock / spring set up. You should also, as well as every body buying shocks
No you need to do some research, start by acting like your going to buy some Elka's and look at all the questions they ask you, maybe then you'll understand. There's no one fits all shock.I don't think you understand the value of the experiences of others. IMHO, Hondasxs.com is EXACTLY the place to begin your research efforts. I never said this is the ONLY research he needs to do.
Chicken! Do some research!No, he's relying on here say. Go read it, shock / spring set up. You should also, as well as every body buying shocks
I will say this one more time. Well Im sure Ill say it a dozen more times cuz people dont listen 🤣I appreciate your response. I’ll try it without the axels.
As far as shocks go, I’m not wanting to spend 1200 on new shocks but my current shocks suck. I wasn’t looking for the lift but they have them. This seems like a good value option to improve shocks.
At the risk of setting another response about checking the other posts. I see that going with 30s is the safest option with the Superatv forward an arms, I’m a tusk fan and I see that I can get 31x10x14 that will fit. How many guys have tried 31s with these an arms. There were a couple places at Royal Blue this weekend I could have used 31s 30s probably would work too.
Sorry, @Smitty335, but you're not paying attention to the point I'm making.No you need to do some research, start by acting like your going to buy some Elka's and look at all the questions they ask you, maybe then you'll understand. There's no one fits all shock.
Me sharing MY experience with something is not hearsay. I have direct knowledge and experience with what I'm sharing, which is precisely what makes it NOT hearsay.Chicken! Do some research!
Unfortunately, there isnt really “value shock” but the ones your first posted about. But one things for certain, anything is better than stockers and $700 is a good down psyment or will get u half a set! 🤣Does anyone know of another value shock that is better than Oem Honda shock. I’m looking to spend 700 on completed set
It's a sad tale of early onset dementia.And why are you quoting and replying to yourself?
If thats all you have then yes, get some fronts to start with the the rears. A buddy did that, but it wasnt much longer till he got the rears.I have 700 to spend, should I spend 700 on front and leave back ones stock? I only notice problems on front. Will this cause other problems?
Great point!Replacing only the front shocks may improve the ride quality. You will not be able to "lift" the pioneer without front and rear shocks.
Adding to what i was saying here…If it was I, and i had $700 after all that, Id get the shocks and arms and do wheels and tires later. Better and easier that way
I bought super atv arms, My budget for shocks is 700$. I’ll buy tires later. Thank you guys for your counsel. It’s been very helpful. I think I’m going to buy a full set of the shocks for 700$ It it’s good to be able to bounce stuff off of experienced guys. Btw, my pioneer with 28s got through Royal blue as good as any other machine I was with. Except for this. If you look close you can see my wife standing on the dash to keep her butt out of the mud. That’s on the trail to Town Rock.Great point!
Im assuming $700 is all he has, he didnt specify if its after the arms and tires or just it?
