Four Cylinder Honda Talon
Jon M
Jon M
60
179
Phoenix AZ
  1. Talon X4
My ridding buddy just bought one of them Polaris RZR's with the fancy four cylinder motor.
It got me thinking; what would the Honda Talon version of this look like?
Honda has a huge parts bin with lots of different four piston engines and matching transmissions. They have lots of options to make this machine but what engine and transmission would be the best suited for a four cylinder Honda Talon?
Here is my paper version of a four cylinder Talon:
Motor: K24W7
Output is 205hp in the Acura TLX. This could easily be bumped to 220+ with a tune, or 250+ with cam, heads and piston redesign.
Transmission: Acura 8-speed DCT.
It exists. It is compact. It has already been developed. IT HAS A TORQUE CONVERTER FOR CRAWLING!!! Given its current application, it could be "most easily" tuned for off-road use. Ratios and splits are similar to the current Talon DCT. Below is a comparison:
1st - 3.08 - 2.764
2nd - 2.18 - 2.047
3rd - 1.61 - 1.583
4th - 1.22 - 1.230
5th - 0.96 - 0.968
6th - 0.74 - 0.800
7th - 0.62
8th - 0.48
The obvious issue here is gearing, which is caused by a lack of subtrans and the tall overdrive gearing in 7th and 8th. There are a few options for fixing the gearing issue:
1. Develop and produce a subtrans with a high range ratio of 2:1 and low range ratio of 3:1.
2. Low differential gearing - like 4.88:1 low (Jeep guys and crawlers know what i mean here).
3. Eliminate 7th and 8th gear. I dont know if this is possible but I'll throw it out there anyways.
(I did not include a primary reductions unit since this would involve redesigning the engine/transmission interface and it would also multiply the amount of torque that the transmission experiences.)
Employing options 1&2 above:
With 32" tires at 70 mph, cruising rpm is 5300 in 6th, 4400 in 7th and 3400 in 8th.
With 34.5" tires in 1st gear, crawling rpm is 2200 at 5mph and 3200 rpm at 7mph.
Employing option 1&3 above with 3.73:1 differential gearing:
With 32" tires at 70 mph, cruising rpm is 4000 in 6th.
With 34.5" tires in 1st gear, crawling rpm is 1600 at 5mph and 2400 rpm at 7mph.
Chassis: The other issue here is that four cylinder engine/transmission/subtrans combo is significantly larger than the current engine/transmission/subtrans combo. Also, the differentials will need to be redesigned to withstand the additional torque. This will also change the suspension geometry to accommodate the large drivetrain. An entirely redesigned or new chassis is needed.
I am not a fabricator or chassis builder and have very little experience or knowledge in these things. Maybe someone else can weigh in here... Lets keep the final weight to 2500lbs or less.
Well... Thats the 4 cylinder Talon that kept me from sleeping last night.
Stupid RZR!
hondabob
1,261
5,004
Prescott Valley, AZ
The 45 year old 1000 cc Gold Wing flat four would be my choice from Honda. Honda could also offer a twin turbo version. With all this Stupid Rush to EV's I think it's best to save up and buy several Pioneer's and Talon's a few years before 2035.
HondaTech
V-4 engines are BAD to the BONE! You can do a lot with one of those.
The National Forest Service doesn't even have power at trailheads so how would everyone charge their EV's on the trail?
V4s are awkward and screwy.
They sound like half the cylinders are missing half the time. Leak more coolant than they hold and suck to service.
272,137
That's the rub, tree hugger EV evangelist don't want you on the trail at all.
Reactions: Jon M, lee and CID
ODAMO
ODAMO
1,283
3,450
Ohio
By 2035 EV tech. will be far superior to whats out today.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Built motor and turbo, 300 hp, would be a lot cheaper.
Reactions: TripleB
HUCK
HUCK
1,047
2,319
ARIZONA
Maybe if they fix the ROPs .
5,425
24,913
Turbo is certainly fun but not conducive to my riding style. I like crawling. So low rpm torque is what i need.
I also like simple. Turbo adds complexity and not worth the added power for my riding style.
#metoo - everything you said and I just don't like the idea of a red hot glowing meteorite melting everything in the area.
1664478588716
Jon M
Jon M
60
179
Phoenix AZ
  1. Talon X4
Electric?
Don't have an emoji for stirring a pot
So here's the thing, you ain't wrong...
There is something to be said for a flat torque curve along the entire rpm band. For crawling, electric appears to be the perfect solution... on paper. However, electric comes with its own set of significant issues; range, range extension, fuel availability, water/weather proofing, repairability, etc. etc.
We'll just leave it at that...
This thread ain't the place for that discussion. I'd prefer to see other folks version of the ideal four cylinder Talon.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Buick 215ci V-8 ;)
  • Love
Reactions: CID
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Got 2 in the barn waiting on something.... lol
  • Love
Reactions: CID
