P1000 Frame Crack
Big-C
10
az
Well well well. Guess I’m making some calls Monday. Thank you thank you! Not sure why the dealer is trying to swap the whole frame? Or why Honda is gonna pay them to do more work than needed to fix the machine??? I’ll let you guys know what I find out. Thx again this is a great community.
68,423
Honda is ass-backward sometimes. This will be fully a dealer decision. Your pressure on them to not have the majority of the unit disassembled will play a big factor.
Honda would rather replace a full wire harness than re-crimp 1 busted connector.
Trail_Rider
Trail_Rider
17
69
Powderly, KY
No update yet. I'm deployed so my wife is going to have to keep checking in with them. Good thing with me being gone, is they've got the time to fix it (hopefully) without me needing it at least.
1st and always, THANK YOU FOR YOUR SERVICE!!! It looks like Honda is having a quality issue. I hope they listen and take steps to stop this and repair or replace the faulty frames. I will be checking mine over closely! Thanks and please update us on what happens!!!
P
Paperdink
Ontario, Canada
@Big-C
Here is one I did myself.
We have the same issue with our P10005 . I am in Canada are all you in the U.S. Honda dealer doesn't think it's a Honda issue but I have just read and seen pictures just like ours. There must be more out there
ODAMO
ODAMO
1,400
3,674
Ohio
Am I correct that Honda addressed the front A arm tearing problem ? If so we all owe a bit of gratitude to you guys on here "Pioneering" a better machine moving forward....Thanks
ToddACimer
ToddACimer
Pioneer 1005-2
3,812
16,232
Oshkosh, Wi
For 2022, Honda changed the front frame and a-arms. The upper a-arms now have 2 bolts rather than 1. This should stiffen up this joint but I still would have preferred a gusset from the forward most a-arm tab into the frame along the bumper. It's likely Hondas fix will be good enough for most people. With the tabs as thin as they are, in a hard impact we may still see the front bolt tear out of the frame but I think the chances of the tab tearing off the frame are greatly reduced
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
If I'm not mistaken, the 22s use 2 shorter bolts for upper fronts instead of the one longer bolt. I was planning on doing that to mine whenever I had time to build my own arms.
DRZRon1
DRZRon1
1,452
4,435
PA
That sucks
U have a buddy that is mechanically inclined - get it lined back up, weld it, reinforce and get riding?
Scoop
Scoop
5,440
21,394
  3. Talon R LV
Curious if anyone has tried the TTC frame kit?
Pioneer 1000 Front Lower Weld In Gusset Kit | Texas Tough Customs
any chance anyone makes an upper frame version of this? (maybe i missed it)
I bet thier weld-in gusset kit works wonders, but they sure could use a proofreader for thier web site descriptions ... :D
Screenshot 20230910 084449 Gallery
