Front differential noise
906UP
906UP
13,000
121,165
da Yoop
Anyone else notice a high pitched whine from the front diff on deceleration when in 4wd? Mine has done it since day 1. It sounds like either the pinion depth isn't set right or ring gear backlash is too tight. Mine's still under warranty but getting it to the dealer is a pain in the d#ck. My dealer closed and the next nearest is 2hrs plus away plus I'm gone during the week for work. I think I'm going to pull the diff, inspect and re-do the set up. Something is off. Probably wait till after next weekend. Just curious if others have noticed it.
Before you ask, this is not coming from the sub trans, definitely front diff noise. The oil is full, I just changed it again to check for debris, none found, the oil is always clean. It doesn't look to difficult to remove & the shims are pretty cheap so I'm not worked about the costs.
319,710
Both Talons I’ve driven did this. Only in I-4wd though, neither made that noise in 2wd. Definitely comes from the front end.
Reactions: Mopower58
5,023
22,429
I noticed mine was noisy in i4wd, turns out my left front axle is leaking at the differential and I was 6 oz low. Dealer ordered the seal, will call when it gets here.
906UP
906UP
13,000
121,165
da Yoop
I get the same noise only in 4wd. Think it’s because of the straight cut gears on the front.
For sure, I'm sure everything is fine & within Honda spec on mine, I'm just curious if it can better....quieter. I don't hear it on accel, only decel. My plan is to pull it and check the contact pattern, pinion depth, etc.
PaulF
PaulF
1,462
4,810
Straight cut gears generally whine. Not sure why they are common in the front diff but at least I always know when I am in 4WD without looking at the tiny indicator on the gauge I can't see :) .
Not much you can do to make it quieter except try some different gear oils. Redline Shockproof is know to quiet up gears, I might give that a try...
1590596065003
1590596176294
319,710
Lucas 85-140 quiets the Pioneer pretty well.
906UP
906UP
13,000
121,165
da Yoop
View attachment 204653View attachment 204654
I agree, gears are my business. It could be very well that everything is fine. I'm just curious is all, maybe I should have explained better. I expect noise/whine given the design, my interest is that there is such a difference in the whine from accell to decell.....as in Night & Day. That's what makes me wonder if the set up of the pinion depth/backlash is not optimal. Its probably nothing but I'll still probably tear it apart just to satisfy my OCD.
PaulF
PaulF
1,462
4,810
Maybe this has something to do with it?...
1590602892219
906UP
906UP
13,000
121,165
da Yoop
The parts lists show the front as 13/44 front, 13/46 rear.....lol. I'd bet money they are the same exact ratio front & back. I found this same error when researching the P500 gear mod also. The parts lists showed different ratios but it was a typo, they were actually the same.
5,023
22,429
Decades ago it was common practice in 4wd vehicles, they wanted the front end pulling the rear; they didn't want the rear pushing the front if I remember correctly.
G
GWH
748
2,475
Las Vegas Nevads
Check the play in the pinion bearings,or hopefully lack of.the fact u can vary the pitch of the whining by loading and unloading the torque on it, I’d agree something is moving w the contact patch of the teeth.
Reactions: 906UP
PaulF
PaulF
1,462
4,810
I can't stand conflicts (my OCD kicked in as soon as you posted that) so I jacked mine up and started rotating wheels and counted. For my machine (2019 R), the service manual is correct and the parts list is incorrect. Front is 13/44 and the rear is 13/43.
Mine has had a slight whine/rumble (however you want to describe it) while decelerating in 4WD at higher speeds since it was new. Dealer said it is normal. A little less noticeable after changing the diff oils. Much more noticeable on hard pack then it is in sand. My previous Rhino and by BIL's RZR make similar noises.
906UP
906UP
13,000
121,165
da Yoop
Maybe I should try some different oil first but it bugs me. I work with gears & gear design and know something isn't right, or as "right" as it should be. At least the went with spiral bevels in the rear 🤷‍♂️
906UP
906UP
13,000
121,165
da Yoop
My curiosity got the better of me today so I took the front diff out of the Talon. I checked the backlash, it was within spec (0.050mm-0.250mm) but on the high end @ 0.190mm. I had shims of 2.06mm on the right and 2.18mm on the left. Per the service manual the backlash is changed by 0.060mm when changing the shim thickness on the left by 0.120mm so I swapped the shims left to right, the backlash is closer to 0.110mm.
20200809 154612 20200809 162914 20200809 163027
So after all that how's the gear whine?........exactly the same :mad:
I get that straight cut gears are noisy but they can be so much better, I guess it's time to find some better oil 🙄
Hometeam
Hometeam
937
3,687
Normal, IL
View attachment 217765 View attachment 217766 View attachment 217767
I just changed all my Talon's fluids over to Amsoil. It made a difference on how smooth it shifts and the diff noise is less. How much less is subjective but I definitely notice a difference in it. I did this to both my Pioneer 1000's and it was noticeable in those too! I run Amsoil in everything I own. I put it in my YXZ and made a difference in it also! Might be worth a try!
TMCCOY
27
34
I used Redline heavy shock proof in the diffs and I think that helped with the noise.
