906UP
Anyone else notice a high pitched whine from the front diff on deceleration when in 4wd? Mine has done it since day 1. It sounds like either the pinion depth isn't set right or ring gear backlash is too tight. Mine's still under warranty but getting it to the dealer is a pain in the d#ck. My dealer closed and the next nearest is 2hrs plus away plus I'm gone during the week for work. I think I'm going to pull the diff, inspect and re-do the set up. Something is off. Probably wait till after next weekend. Just curious if others have noticed it.
Before you ask, this is not coming from the sub trans, definitely front diff noise. The oil is full, I just changed it again to check for debris, none found, the oil is always clean. It doesn't look to difficult to remove & the shims are pretty cheap so I'm not worked about the costs.
