I know this seal leaking problem has been beat to death. I haven't had the privilege to replace mine yet. Warranty did it once. I don't know what the bearing placement looks like or if there is a bleed back for oil on the outside of the bearing. My thought for a possible cure-Why not put a sealed bearing in? The existing seal could still block most dirt and water from entering from outside. Without oil on the lip seal meniscus, it might wear. But it would still do it's job. Has anyone tried this yet? If my next seal failure isn't covered by same problem after warranty repair, I will try it.
