Front Recovery Spot?
Shiyuki
5
EDMONTON
Anyone know a good way to get a strap safety to pull out machine if stuck. Have the Honda steel front bumper.
Backwoods
Backwoods
35,782
362,078
Douglasville ga
Put on a winch and also fab up a shackle to your winch mount.
Reactions: Mudwing
PaulF
PaulF
1,462
4,815
Never tow or pull from any suspension part. The strongest (and easiest to get to) part up front is the stock bumper, just below the upper frame on either the left or right (never pull on the top of the bumper)...
1596152622496
This is also where your owner's manual says to strap the machine down during trailering...
1596152772193
Shiyuki
5
EDMONTON
I need it for if i get stuck. What are people doing for adding something to the front to pull out.
HondaTech
I wouldnt pull from the stock front bumper, its weak as heck.
PaulF
PaulF
1,462
4,815
I wouldbt pull from the stock front bumper, its weak as heck.
I would disagree with that statement for 4 reasons.
1) Honda tells you to tie it down there. They would not do that if it was "weak", the liability would be enormous.
2) It is not weak if you use the pull point I mentioned but it is not as strong as the frame.
3) I would much rather the bumper bend than the frame when trying to pull a machine out.
4) I have bottomed out many times in the sand and bent the s*** out of a stock bumper and it has never broken a weld or mount bolt.
Reactions: Moab_Marty
PaulF
PaulF
1,462
4,815
I use my winch which is attached to the upper vertical square tubes on the front bumper. I have used a tree saver strap wrapped around the bumper tube where I pointed out to pull my buddy out a couple times.
