P1000m5 fuel problem
don don
mich
Hello Don Don here . Have a 1000-5 motor cutting out fuel problem. could this be due to injector wiring plug ?if so how do I trouble shoot?
Reactions: TxDoc
66,870
There is also a fuel pump recall as of last month.
With the injectors. Usually it's the wireing thst breaks. It will not be visible.
To test. Let it idle and wiggle the injector wires around. If the pattern changes then they need to be replaced because it has a broken wire.
Seems to be fairly common.
Reactions: BWAF
