i was driving my 2018 1000-5 LE in the snow last week and out of the blue it just shuts off. I lifted the seat and couldn't hear the fuel pump so i assumed the pump just died (tank was full of fresh fuel). After getting it towed home, i ordered a brand new fuel pump and put it in but still nothing. I also tried a brand new battery just in case. I checked all the fuses (which were good) and swapped the fuel pump relay with one of the other functional relays (low beams) and that didn't do anything. The whole time I did a voltage test at the pump (between the green and brown wires) per the service manual and i never got any voltage so i'm assuming there's a break in the wire somewhere or something is up with the computer/PCM. I don't want to start pulling wires so i've got three questions for y'all
1. do you think my assessment of the situation is correct or am i missing something?
2. could i run wires directly from the fuel pump relay to the pump to see if it really is a wire issue. If that's the culprit i'm fine with pulling wire harnesses apart and rewire it.
3. Or any other suggestions?
at this point, i'm happy to take it to the shop but my local honda dealer said the soonest i can drop it off is almost 4 weeks out. I just got tracks on this thing this winter and the snow is epic right now and i want to get it back out there!
any and all suggestions are greatly appreciated! here's the beast.
